Laptop charger for charging Mini3 batteries?
2404 9 2023-6-16
Simulcop
Colombia
Hi everyone, I'm new here in the drones universe. I've just bought a Mini 3 and I was wondering if it's safe to use a laptop charger for charging the Mini3's battery. Below a photo of the charger output details. Cheers
2023-6-16
DJI Gamora
Hi, Simulcop. Thank you for reaching out. We will coordinate this to our relevant team for further checking. We will keep you posted. Thank you.
2023-6-16
nazgull
Short answer: No.    Short explanation: Your laptop charger output voltage is too high.
2023-6-16
Speedie
Flight distance : 44682 ft
Sweden
Short answer: That charger will be just fine. Im using a similar one but from HP.
Long answer: The batteries/charge hub and the charger will do a handshake when connected and communicate the maximum allowed charge voltage which is 15V (according to the Mini 3 manual) and then the batteries will draw the amps they need. If a charger does not support 15V output they might fallback to 9V and if that is not supported then they will go with USB standard 5V.
2023-6-16
nazgull
ah! That'll  teach me! RTFM! ...
2023-6-17
DJI Gamora
Hi, Simulcop. Thank you for patiently waiting. We now received feedback from our relevant team. Please confirm first if the charger support PD fast charge protocol, if yes, you may use the charger normally, which will automatically decrease the power; if it does not support PD charge protocol, the power will limit to 10W, which also can be used, but the charging time will increase. Hope this helps.
2023-6-19
Simulcop
Colombia
Thanks everyone for your replies. I'll check about PD charge protocol and update here.
2023-6-19
nazgull
I don't have a charging rack for batteries so any decent 5v wall-wart works for me but it's passing strange if they don't include a charger with the rack?
"Power cable is not included.
Specifications
Input: 100 to 240 V, 0.8 A, 50/60 Hz
Output: 5V/3A, 9V/3A ,12V/2.5A, 15V/2A, 3.3 to 11V, 2.72A"
2023-6-19
_dji_user_
Flight distance : 1784442 ft
Estonia
nazgull Posted at 2023-6-16 08:01
I also use a lenovo 65w usbc laptop charger and everything works great.
3-2 17:21
harweyko
Flight distance : 627300 ft
Slovakia
All these Lenovo notebook chargers with USB-C now use PD 3.0, so should be safe to use. I charge my drone with 95w Lenovo charger and had no problems, the battery will pull just the power it needs, nothing more.
3-2 23:49
