Mini 3 Pro and accessory weight
824 10 2023-6-18
KBear
I have some weight scales for you guys and gals.
Stock, bare bones with stock Intelligent Flight Batteries. No accessories
Stock, bare bones with stock Intelligent Flight Batteries. Including aftermarket folding Landing Gear by STARTRC.
Stock, bare bones with stock Intelligent Flight Batteries. Including aftermarket folding Landing Gear by STARTRC and DJI 360 propeller gaurds.
2023-6-18
Ranjan
India
Good information, thanks for sharing.
2023-6-18
KLRSKIR
Flight distance : 28368625 ft
Interesting. I just weighed my Mini 3 Pro yesterday with a Taylor scale. With the "249g" battery and Master Airscrew props it weighs 247g. Just posting for reference.
2023-6-19
Blackbuckone
Flight distance : 68967 ft
Useful and interesting, I also have the same landing gear.
2023-6-19
AsturianCetorix
Flight distance : 46814 ft
Interesting.
Here in Europe, the politicians think that the Mini 3 Pro is almost a Boeing 747 filled with explosives if it weights more than 249g...
This little machine is very capable, all that stuff compressed in a so lightweight package that you can barely put some sticks on it without a legal-trouble-weight increase...
2023-6-19
DowntownRDB
Flight distance : 1722 ft
Interesting and thanks for sharing.  Seems each Mini 3 Pro can be a tiny bit different in weight.  My Mini 3 Pro Stock, bare bones with stock Intelligent Flight Batteries weighs in at 248G.
2023-6-19
KBear
You are very welcome for the info. Just thought it would be handy if you might have questions or thoughts about these accessories.
Not sure why weights can vary. Scales and scale calibration can play a role maybe?
2023-6-19
MRDroneRookie
Flight distance : 2007070 ft
KBear Posted at 6-19 17:09
I have a very accurate scale that has a resolution down to 1/100th of a gram. I have calibration weights that I use to calibrate it. I have found one of my regular batteries is more than a gram heavier than my other two. The following are the weights of my drone with each battery (and DJI props). Battery 1 = 247.23 gr, Battery 2 = 247.09 gr, Battery 3 = 248.30 gr. With my plus battery = 286.89 gr. My Master airscrew props weigh an average of 1.09 gr for each blade for a total weight of 8.72 grams for the set of 8. The weights were 4 blades @1.09gr, 2@ 1.08gr, 2@ 1.10gr. The DJI props props weigh an average of .94 gr per blade for a total of 7.5 gr for the set of 8 making the Master airscrew props more than a gram heavier than the DJI props. With my heaviest regular battery the Master Airscrew props bring it very close to the 250g limit but just under at 249.48gr.
2023-6-19
DAFlys
Thanks for sharing.
2023-6-20
Mirec5050
Flight distance : 656555 ft
Slovakia
I bought a "plus" battery, a chassis and a stroboscope for the drone... the weight is now 315g.
2023-6-20
KBear
MRDroneRookie Posted at 6-19 19:06
Wow, that's great. And as others have stated thank you for sharing!
2023-6-20
