Accessing distance laser data in log file
1044 14 2023-6-22
dji_dicle
Turkey
Hello,
we have a dji rtk matricies 300 drone. I would like to access drone distance data. I looked into log file data but unfortunatelly I could see no data about distance sensor. How can I reach it ?
Best regards.
2023-6-22
DJI Gamora
Hi, dji_dicle. Thank you for reaching out. You may check the flight log on the remote control side to see the total mileage for each flight, please refer to the screenshot below:
2023-6-23
dji_dicle
Turkey
DJI Gamora Posted at 6-23 07:56
[view_image]
Hello DJI Gamora,
Actually I don't mean traveled distance. What I mean is that, when you look at somewhere with the drone, a sensor measures distance between you and where you are looking. How can I access this distance?
2023-7-6
DJI Gamora
dji_dicle Posted at 7-6 03:29
Hello DJI Gamora,
Hi, dji_dicle. Thank you for the reply. Let me confirm this with our relevant team. We'll get back to you once we receive feedback from them.
2023-7-8
dji_dicle
Turkey
DJI Gamora Posted at 7-8 19:36
Hello Gamora,
Thank you for that, I would be waiting you.
Best regards.
2023-7-10
dji_dicle
Turkey
Hello DJI Gamora, could you find something ?
Best regards.
2023-7-13
DJI Gamora
dji_dicle Posted at 7-13 06:44
Best regards.
Hi, dji_dicle. Thank you for patiently waiting. Please check the feedback below:
For this function, the aircraft does not have relevant sensors to calculate it;
But it is possible if you have an H20 camera, which has a laser ranging function. You can measure the distance between the aircraft and the target point through H20, or mark the target as a Pinpoint. You can control the aircraft to reach the Pinpoint later.
2023-7-17
dji_dicle
Turkey
DJI Gamora Posted at 7-17 07:54
Hi Gamora,
Thank you for reply and concern. We have H20T and it is installed on the drone. However, I do not see any data about its lidar laser range finder in flight records. How can I access it?
Best regards.
2023-7-17
DJI Gamora
dji_dicle Posted at 7-17 21:21
Hi Gamora,
Hi, dji_dicle. Let me verify this with our relevant team. We'll get back to you once we received an update.
2023-7-19
dji_dicle
Turkey
DJI Gamora Posted at 7-19 06:18
Okay, I am waiting your response Gamora.
Best regards.
2023-7-30
grone
Flight distance : 2342628 ft
Hello, I have the same issue... and we need help. Thank you.
2023-7-31
DJI Gamora
dji_dicle Posted at 7-30 21:31
Best regards.
As shown in the attached screenshot above:
The red arrow icon on the left side of the screenshot is to enable/disable the H20/T20T laser ranging function. The Red Cross icon in the middle of the screenshot is the target object to aim at, and the RNG next to it represents the distance between the camera and the target. This data will not be recorded in the flight record, and this function needs to be turned on in real-time. Hope this answers your question.
2023-8-5
DJI Gamora
grone Posted at 7-31 05:24
Hi, grone. Please refer to my reply above. Thank you.
2023-8-5
dji_dicle
Turkey
DJI Gamora Posted at 8-5 20:58
[view_image]
Hi Gamora,
Thank you for your answer and interests. Why it needs to be just real-time? I think it should be to record. Maybe there is an another option, for example third party softwares. Is there any way to get it after fly?  Can we use DJI SDK to record?
Best regards.
2023-8-6
DJI Gamora
dji_dicle Posted at 8-6 21:02
Hi Gamora,
Hi, dji_dicle. The laser rangefinder function needs to be turned on in real-time, but the information is recorded in the photo. (The premise is that the camera needs to take pictures.)
As shown in the screenshot below, if the laser ranging function of the camera is turned on, the target distance will be recorded in the XMP information of the photo taken by the camera;
drone-dji: LRFStatus: laser ranging radar status;
drone-dji: LRFTargetDistance: the distance between the target object and the camera;
drone-dji: LRFTargetLon: laser ranging longitude of target object;
drone-dji: LRFTargetLat: laser ranging latitude of target object;
drone-dji: LRFTargetAlt: laser ranging the relative height of the target object;
drone-dji: LRFTargetAbsAlt: Laser ranging absolute height of target object (ellipsoid height).
If you need to record through third-party software or SDK, please contact the SDK team at dev@dji.com.
2023-8-12
