Mini 3 Pro "max flight distance reached" frustrating!
7576 21 2023-6-29
MaybeJaybe
Flight distance : 2057 ft
I have googled this pretty extensively and I have yet to find a suitable solution. I've also been in contact with DJI twice today and they also can't help apparently. Any time I use automated functions like MasterShot i get the error message "max flight distance reached. Adjust aircraft distance and start again". The problem is, I'm not even far from the subject so it's definitely within the limits set in-app. The only work around I have found is to move the home point right next to the subject but that's not very helpful when I want to use that as a safety feature, or it's not a good place to actually come back to. Anyone know of any work around at all?! I can't even reinstall the firmware according to DJI Assistant. Incredibly frustrating.
2023-6-29
DJI Diana
Flight distance : 2408 ft
Hi. I apologize for any inconvenience this has caused. May I ask what version of the DJI Fly app you have? May I also confirm your highest flight altitude? For your feedback on our services, could you please confirm through which method you contacted our support? I look forward to hearing back from you. Thank you.
2023-6-29
hesveymartin
Flight distance : 192825 ft
Philippines
Maybe you can check "Max Distance" setpoint under Safety > Flight Protection > Max Distance? hope this helps..
2023-6-29
MaybeJaybe
DJI Diana Posted at 6-29 15:42
The latest version so it’s set to the highest I can go at 120 meters. I contacted through the online chat service. It was painfully slow.
2023-6-29
MaybeJaybe
hesveymartin Posted at 6-29 21:34
Maybe you can check "Max Altitude" setpoint under Safety > Flight Protection > Max Altitude? hope this helps..
[view_image]
I have distance set to unlimited and height to 120 meters. I wasn’t even flying anywhere near that high.
2023-6-29
hesveymartin
Philippines
MaybeJaybe Posted at 6-29 22:15
Did you notice the number or strength of GPS signal during your flight?
2023-6-29
UweE
Flight distance : 1242211 ft
can you check, whether you are connected to your DJI-account?
If not, there are some restrictions which can cause your problem.
Or are you using a prop-guard?
2023-6-29
MaybeJaybe
hesveymartin Posted at 6-29 22:39
[view_image]
It happens no matter where I am and the gps has typically been good.
2023-6-29
MaybeJaybe
[view_image]
2023-6-29
MaybeJaybe
UweE Posted at 6-29 22:59
I’m connected. Saw somewhere that logging out and in again my fix the problem but it didn’t. Not using a prop guard no.
2023-6-29
JJB*
Flight distance : 13955751 ft
MaybeJaybe Posted at 6-29 23:04
HI,
Fly again, screen record your flight.
Share the screen recording and your flightlog for this issue.
Use > https://www.phantomhelp.com/LogViewer/Upload/   post the uploaded link on here
(add video on here  or  put a cloud link to the video)
cheers
JJB
2023-6-30
MaybeJaybe
JJB* Posted at 6-30 04:35
HI,
Already done this and sent to DJI upon their request
2023-6-30
JJB*
MaybeJaybe Posted at 6-30 04:38
oke,  but if you like to get second and often better opinion....share your log ect
2023-6-30
WN1X
Flight distance : 37884 ft
Post the link to your log so others can comment on it, besides DJI.
2023-6-30
DJI Diana
MaybeJaybe Posted at 6-29 22:14
Thank you for the information. DJI Fly has been updated to v1.10.6. Could you please update the DJI app and check again? Please download the latest version from our official website at https://www.dji.com/downloads/djiapp/dji-fly If the issue persists, please let us know. Thank you.
2023-6-30
Hi there, we notice our team has provided you with the corresponding suggestion in the email. May I ask if you have tested it? If the issue still exists, please let us know.
2023-7-7
tazzt0ne
Flight distance : 1240184 ft
Switzerland
ok my mini3pro also encountered this for the first time while doing hyperlapses.
as can be seen on screenshot i get this warning "Aircraft max flight distance reached. Hyperlapse exited" as soon as i start the hyperlapse. the image counter just stays at 0 and the drone idles, even though the red button indicates the hyperlapse has started.
on 2nd screen u can see my max distance is actually set much higher.
what is the reason for this behavior?
using latest dji fly app and firmware.
2023-9-28
fansc08a1af2
Flight distance : 4658087 ft
I can attest to this issue too but I’m flying my new Mavic 3 Pro. I’m in class C airspace with proper authorization and I can not use my intelligent flight modes without getting that same error message. I’m out on a job and this is extremely frustrating and losing me money… Using the RC Pro and ALL firmware and software are 100% up to date on all systems. DJI this is unacceptable to spend $4k on a drone system and still have these money crippling bugs. This is where competitors are born.
2023-10-28
Hoarfrost
Flight distance : 705974 ft
fansc08a1af2 Posted at 10-28 16:47
After doing some research I can see that this has popped up from time to time over the years. Most often it was after a firmware update when settings were put back to default.
The most common fix was logging off. Shutting down the Fly app and restarting and logging back in and resetting all your parameters.
Sorry - that's all I've got if you already tried that.
2023-10-28
Ren2024
Philippines
Hi Admin,
Permission to post!
I would like to ask for help with regards to my Mini 3 Pro drone. It prompted an error: "Aircraft Max Flight Distance Reached," even though the settings for the distance were set to no limit. I am using an RC controller.
I hope someone helps me.
Thanks!
2024-4-9
DJI Paladin
Flight distance : 318 ft
Ren2024 Posted at 4-9 18:53
Hi Admin,
Permission to post!
Hello, Ren2024. Thank you for reaching out and we're sorry for the trouble. Can you try to perform a test flight in a different location to check if the issue persists? Also, please check the location that you are flying if it is within the DJI No-Fly zone as flying in these areas is restricted. If the issue persists, download the DJI Assistant 2 software and update/refresh the firmware of both the aircraft and remote controller. Please keep us posted.
DJI Assistant 2 software: https://www.dji.com/global/downl ... sumer-drones-series
2024-4-10
dmac_sail
Hoarfrost Posted at 2023-10-28 19:23
I wish I read this before upgrading the controller firmware today.  After the upgrade, things looked ok.  I started flying the drone over my son's sailing regatta.  After about 500m I got the "max flight distance reached" warning.  I tried to bring the drone back, but it would not come back fully (it was still out some 50m), no matter what I tried.  Eventually, one of the boats hit it and it went for a swim.  This is not the right way to do a firmware upgrade, DJI.  I do hope they take responsibility for destroying my drone!
2024-11-9
