Follow terrain height
1275 4 2015-8-28
Adamastor
Flight distance : 616079 ft
South Africa
Question...
How can I fly with the ultrasonic sensor for establishing height above ground?
I do missions over very uneven terrain.
I start at say 25m height on the display bottom left in the App and then had to drop manually to about 4m to still clear a fixed height obstacle low enough to see details clearly.
This is very confusing...
In other words, how can I set a flight path height to clear fixed height obstacles, but follow the uneven terrain?
This could be power lines for instance, in semi mountainous terrain.
2015-8-28
Linolens
Flight distance : 501250 ft
Macao
If you're flying near power lines, you're doing it wrong.
That's a no go.
As far as I'm aware there's no software available that reads altitude on the fly and adjusts itself according to terrain variations relying on the barometer.
Even when and if DJI's autopilot comes out, the flight has to be pre-programmed from point A to B and it's respective altitudes.
2015-8-28
Adamastor
South Africa
Hey Linolens
Thanks for the reply...
Well... then I just have to wait for the "autopilot / waypoint flight" from DJI - if it ever materializes.
And yes, I was sort of expecting to pre-program the co-ordinates plus the height above ground for the entire route.
For now I'll just keep on following the aircraft in close proximity to keep out of trouble
2015-8-29
InspireHelp
I doubt we'll see any apps that auto fly the Inspire 1 at a set altitude above the ground. That would require the use of VPS -- and, that sensor is not accurate enough when over certain types of terrain to safely take on such a mission.
www.InspireHelp.com
Find the latest must-haves, fixes, mods, how-tos, guides, and accessories for your Inspire.
Inspires in stock and ready to ship worldwide! (see availability)
2015-8-29
Adamastor
South Africa
Hey InspireHelp
So I won't be able to fly it like a MQ-9 Reaper... damn!
2015-8-29
