Battery Charging Hub
802 8 2023-7-2
Shawgod
Flight distance : 5173104 ft
Today when I am charging my batteries in the battery charging hub, I noticed something weird.  I plugged the hub into a plug that apparently was a low power plug because the lights went real slow across.  Then I plugged the hub into my Anker 145 watt charging plug and the lights started to go real fast.  Has anyone else noticed this? I have no idea if that means if the battery will charge faster or not.
2023-7-2
yogi053
Flight distance : 26104915 ft
I haven't timed it but when I charge the batteries in the hub using different powered chargers, the leds flash at different speeds.
2023-7-2
DJI Gamora
Hi, Shawgod. Thank you for reaching out. Can you please share with us a video showing the difference between the lights of the plugs and the specs of the low-power plug for further checking? Thank you.
2023-7-2
Shawgod
DJI Gamora Posted at 7-2 18:07
Where can I upload the video?
2023-7-3
DJI Gamora
Shawgod Posted at 7-3 15:10
Hi there. Kindly upload the file/s to Dropbox or Google Drive and provide us the shareable link via PM. Thank you.
2023-7-4
Shawgod
DJI Gamora Posted at 7-4 07:20
Here is a short video of what I am talking about.
https://youtube.com/shorts/oTcCLb8NTiY?feature=share
2023-7-4
Shawgod
How do I PM you or other Administrators?
2023-7-4
Mobilehomer
Flight distance : 18150351 ft
It IS an indicator of chargeing speed. More amps delivered, faster charge. A good thing.
2023-7-4
Shawgod
Dirty Bird Posted at 7-10 03:03
Your assumption is correct.  The speed of the LEDs indicates how fast the batteries are charging.  In the hub I have seen Mini 2 & Mini 3 batteries charge at up to 36 watts.  A 30 watt or higher PD charger will ensure your batteries are charged as quickly as possible.
Another question I have is, will it ruin the batteries in any way if the batteries are charged too fast?  I am using a 120 watt charger from Anker https://a.co/d/d5J50SB and this is a beast.
2023-7-10
