DJI Gamora
Hi, Darryl. Thank you for patiently waiting. We now received feedback from our relevant team: Depending on your needs, we recommend that you set the file numbering mode to "Continuous". The “File Index Mode” Function can be set for MicroSD Cards. The path is Camera Parameter Setting>Setting>File Number Node-Reset / Continuous.
[Example] File serial number (001,002,003,004), such as deleting 003
【Reset】
1) If you did not replace the SD card (unformatted SD card), the system will start naming from 005;
2) If you replaced the SD card (formatting the SD card), the system will start naming from 001.
【Continuous】 No matter whether you replaced the SD card (whether or not the SD card is formatted), the system will start naming from 005. |
