DJI Mavic 3 Repair Video Guides
4267 7 2023-7-3
HowFixIT
Flight distance : 425384 ft
Hi everyone, Here I have put together some video guides for you, especially if you live in an area without DJI service or if your drone's warranty has expired.
Whether you're a beginner or an experienced enthusiast, these video guides are designed to help you maintain and fix your DJI Mavic 3 from troubleshooting common issues to replacing parts. Take your drone repair skills to the next level!
Drone disassembly
Use this video instruction to disassemble the DJI Mavic 3 drone to replace the body parts, mainboard, GPS module, and vision sensors, or repair the ESC motor control board. The reassembly process is also included in this guide.
*To replace the ESC board or motors of the drone, you will need a soldering iron and some experience with it.
Gimbal Repair
If your Mavic 3 drone crashes and the gimbal is damaged In this video guide, use this video guide to replace the camera gimbal assembly or individual parts. When a drone crashes, the camera gimbal cracks, the gimbal motor breaks, and the ribbon cable or the rubber holders are torn. All these parts of the camera gimbal can be replaced individually, which reduces repair costs.
Fan Replacement
Use this repair guide to replace the fan on DJI Mavic 3 drone. How to fix error code 30135: aircraft processor chip overheating. If your DJI Mavic 3 is overheating and shutting down, your drone's cooling fan is most likely not working and the processor chip is overheating. To fix this problem, you need to replace the broken fan.
GPS module
Use this repair guide to replace the GPS module and fix the GPS navigation system error. If your DJI Mavic 3 drone has a navigation system error, no GPS signal, or GPS is not working, replacing the GPS module may resolve this issue. The GPS module is replaceable and you can replace it at home with the necessary screwdrivers and plastic pry tools. The repair process does not require professional repair skills, all you need is a new replacement GPS module and about 30-40 minutes.
Mainboard Repair
The most common cause of drone motherboard failure is water damage and further oxidation of the components. If your Mavic 3 drone doesn't Turn ON or doesn't respond to the power button, you should check the drone mainboard first.
Camera Replacement
If the camera on your DJI Mavic 3 drone is not working properly or has been damaged, camera repair can help restore its functionality. Instead of immediately replacing the gimbal assembly, opting for camera repair can be a more cost-effective solution.
2023-7-3
Montfrooij
Flight distance : 2770725 ft
Very nice collection!
2023-7-3
DAFlys
Nice guides.
2023-7-3
Burt37
Flight distance : 4009 ft
Yes all very nice videos... Very helpful for the DIY..
2023-7-4
KokoFresha
Flight distance : 4139925 ft
Bulgaria
Thanks for the collection!
2023-7-4
mark11111111
India
This is a valuable resource for me and others. And I'm grateful for your generosity in sharing this with others.
2023-7-24
djiuser_1UwZmTtrgukr
Flight distance : 1733212 ft
Morocco
Is it repairable ? Or it’s needs any coding replacing a new part ?or just replace the damaged part and you’re ready to go ?
2023-9-14
djiuser_PiZN11PEJlOz
I cannot overstate the frustration I experience when I’m searching the net for a video that illustrates step by step how to tear down and rebuild the gimbal on a Mavic 3 Classic. I’m trying to put a new ptz cable in because the old one got torn in crash. There are so many things that lead me to what I’m looking for, or supposedly anyway, only to find nothing. My Gimbal is apart, I have the new pts cable, and I cannot remember how it goes back together…     …PLEASE HELP!!!!!! Please send some schematics or links to help me rebuild my gimbal.
8-21 23:43
