DJI Mini 2 Repair video tutorials
5320 3 2023-7-9
HowFixIT
Flight distance : 425384 ft
Greetings, esteemed pilots! I have compiled a collection of instructive video tutorials tailored specifically for individuals residing in regions devoid of DJI service or those whose drone warranty has expired. Whether you are a novice or a seasoned enthusiast, these video guides aim to assist you in the maintenance and repair of your DJI Mini 2. They cover a wide range of topics, from troubleshooting common issues to the replacement of various parts.
DJI MINI 2 GIMBAL REPAIR
If the gimbal is stuck after a crash and the gimbal camera not works, use this video tutorial to completely disassemble the camera gimbal to replace one of the broken parts. The most vulnerable part of the gimbal is the cable or the gimbal housing itself, and probably the rubber holders that secure the gimbal camera to the drone body are also torn. The good news is that DJI Mini 2 drone gimbal repair does not require special technical skills in electronics repair, all components of the gimbal can be replaced without using a soldering iron or other professional tools. All you need to repair your drone gimbal are screwdrivers and anti-static tweezers.
Ribbon Cable Replacement
In this comprehensive tutorial, you'll learn everything you need to know about replacing the ribbon cable on your DJI Mini 2 drone. Whether you're a beginner or an experienced pilot, this step-by-step guide will walk you through the process with clear instructions. Don't let a damaged ribbon cable hold you back from capturing amazing aerial footage.
GPS module Replacement
In this video, you'll learn how to fix the GPS or IMU data error on your DJI Mini 2 drone by replacing its GPS module. If you're experiencing issues with your Mini 2's GPS accuracy or encountering error messages related to GPS or IMU data, this step-by-step guide will walk you through the process of replacing the module with ease.
*DJI Mini 2 GPS errors:
  • Error code 30049: GPS module error.
  • Error code 30105: Navigation system error.
  • Error code 40021: IMU data error.
  • Error code 30007 and 30008: No GPS signal. Unable to hover. Fly with caution.
DJI MINI 2 GIMBAL CABLE REPAIR
In this comprehensive tutorial, you will learn step-by-step instructions on how to disassemble the gimbal and replace the cable effectively. In case of a damaged gimbal cable, there is no need to change the gimbal camera assembly, you can change the gimbal cable only. Replacing the cable will cost significantly less than replacing the gimbal assembly. Repairing the cable requires screwdrivers and some auxiliary tools. The repair process does not require professional soldering skills.
DJI MINI 2 CAMERA GIMBAL REPAIR
The main reason for a faulty camera on the DJI Mini 2 drone can be a black screen, but the camera gimbal rotates and works properly. Also, the camera may not work after the drone crashes. The good news is the camera module on the DJI Mini 2 drone is replaceable. If the camera is not working, you can replace it and repair costs will be significantly less than replacing the gimbal assembly. Repair does not require professional electronics soldering skills, you only need a screwdriver and some auxiliary tools.
Motherboard Replacement
Water damage and subsequent oxidation of components are the most common culprits behind drone motherboard failure. If your DJI Mini 2 drone refuses to power on or fails to respond to the power button, it is imperative to inspect the drone's mainboard as a first step.
Feel free to leave any questions or comments below—I'm here to assist you throughout this process.
Thanks for watching and safe flying!
2023-7-9
Tom Richard
These are great....Thanks for sharing.
2023-7-9
Montfrooij
Flight distance : 2560453 ft
Very nice series (again)
2023-7-10
Shawgod
Flight distance : 5173104 ft
Thank you for putting this together
2023-7-10
