DJI Mavic Air 2 Repair Guides
1196 4 2023-7-6
HowFixIT
Flight distance : 393435 ft
Hi, guys! Here, I've provided some video guides for you. They will be especially useful if you live in an area without DJI service or if your drone's warranty has expired. Whether you're a beginner or a DIY enthusiast, these video guides are designed to help you maintain and fix your DJI Mavic Air 2, from troubleshooting common issues to replacing parts.
Gimbal Camera Guide
Step-by-step instructions for replacing the Mavic Air 2 camera gimbal assembly or disassembling and repairing individual parts of the camera gimbal. The gimbal is the most vulnerable part of a drone. If the gimbal camera is broken, you can replace the gimbal assembly or individual parts such as the camera module, flex cable, or gimbal housing. Moreover, the repair cost is much cheaper if you replace only the broken parts of the gimbal, rather than changing the gimbal assembly.
Fan Replacement Use this step-by-step guide to replace the fan if your Mavic Air 2 drone has a processor overheating error code 30135. The Mavic Air 2 drone processor chip overheating error is caused due to two reasons, either the fan is clogged with dust and prevents the drone processor chip from cooling efficiently, or the fan is not working. Replacing the fan in this drone model is quite an easy process and does not require special repair skills.
Motherboard Replacement
If you're facing issues with your drone not turning on or responding to the power button, water damage or motherboard failure might be the cause. In this video, we'll walk you through the step-by-step process of replacing the Mavic Air 2 motherboard.
Camera Replacement
The Mavic Air 2 drone's camera may be faulty, but the camera gimbal works fine. In this case, you do not need to change the camera gimbal assembly, you can only replace the camera module separately.
There is also a camera error сode 10001: Camera malfunction. Repairs required. Contact DJI Support for assistance. In case of such an error, you can try updating the firmware using DJI Assistant 2, if that doesn't help, try replacing the camera module.
I hope these repair video guides provide you with the expertise and insights needed to navigate the intricacies of maintaining and repairing your Mavic Air 2 drone.
Feel free to leave any questions or comments below—I'm here to assist you throughout this process.
Thanks for watching and have a safe flight!
2023-7-6
kiminx
Flight distance : 149032 ft
Indonesia
thx you! helpful video
2023-7-7
Montfrooij
Flight distance : 2560453 ft
Good collection!
2023-7-7
DowntownRDB
Flight distance : 1722 ft
Excellent collection of repair guides.    Thanks so much for the work you put into these helpful videos and for sharing.
2023-7-7
djicheaha
Flight distance : 2957598 ft
Thanks for the collection. Hope to not ever need them, but good to have this information (if) needed. Thank you for sharing.
2023-7-10
