Mobile phone screen is going to sleep when flying
2007 6 2023-7-4
Rallye Roamer
Hello all,
first post and new user so please be gentle
I have just bought a mini pro 3 and have a couple of questions.
Firstly on flying my mobile phone screen started going to sleep when the drone was in the air (iPhone 14 pro)
. All the joystick controls were working fine. ie left joystick, up, down, trun left and right. Right joystick forward, reverse move left/right.
So I brought the drone back to land.
Then I tried a second flight, screen still timing out, however I noticed this time that the drone wouldnt move left or right (with the right joystick) but would gor forwards and reverse (left joystick all working fine).
Any suggestions, thanks
2023-7-4
Mobilehomer
Flight distance : 18150351 ft
Check if "Disable Sideways Flight" is enabled. I'm not sure about IOs, but there should be a setting to disable screen timeout per app.
2023-7-4
Rallye Roamer
Mobilehomer Posted at 7-4 08:22
Thanks, I found the disable sideways flight, thats fine now.
Will have a look if there is a setting like that. Strange thing is I had the phone on for much longer when setting up and getting a bit used to it and it didnt lock up. Will see if I can find a setting.
2023-7-4
Rallye Roamer
Cant find a setting to time screen out at all.
2023-7-4
Lieutenant
Does this help ?
https://www.google.com/search?cl ... 9HrOt4-EP-LiwgAQ_37
2023-7-4
Rallye Roamer
Lieutenant Posted at 7-4 17:50
Does this help ?
https://www.google.com/search?client=firefox-b-d&q=iphone+14+screen+always+on#kpvalbx=_HsykZLa9HrOt4-EP-LiwgAQ_37
Yes, that might do, thanks.
Although I charged the phone up to 85% and tried again and it didnt go to sleep. Maybe it is something to do with the fact it was about 30% charged.
2023-7-4
DJI Gamora
Hi, Rallye. Thank you for reaching out. There are no screen time settings or limits in the app, please further check your phone settings. Kindly set the screen lock time to Never and test again. Please keep us posted.
2023-7-5
