DJI Action 2 Black Screen & Micro SD Problem
1424 17 2023-7-5
Arnim
Flight distance : 45417 ft
Only 2 weeks after purchase I have two problems with the DJI Action 2:
1) The dual screen battery module remains black
2) the micro SD card is no longer recognized
I had already put up with the overheating problem. But now that a longer trip is pending, the camera lets me down.
That sucks!
According to the forum, I'm not alone! Have you found a solution in the meantime?
I have already tried all the tips in the forum: Reset, screen on/off settings.
Is there any news?
I really like the form factor! But this still seems to be a pre-production product.
Don't leave me stranded. I don't want to switch to GoPro in the short term now.
Please check my video here:
https://youtu.be/UTfDJe22KpI
2023-7-5
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to remove the cover and test it? If possible please connect the device to the DJI Mimo to check the firmware update notice and please update the firmware if it is available. Please keep us posted. Thank you for your understanding and support.
2023-7-6
Arnim
1) Cover: We tested with and without cover. The screen remains black.
2) Firmware: I updated the firmware last week. When opening now the Mimo app, there is no update request.
I also did a Reset and cleaned the pins - no effect.
We have bought the camera 2 weeks ago on German Amazon and will send ich back now.
2023-7-7
DJI Gamora
Arnim Posted at 7-7 04:02
Hi, Arnim. Thank you for the update and we're sorry to read that the issue persists. Should you need further assistance with the replacement unit, please let us know. Have a good day!
2023-7-9
fansb421f517
DJI Gamora Posted at 7-9 19:02
I have the exact same problem with an older camera,  after updating it to the latest firmware.
The camera notices the display module is there, shows the battery level, and the record button on the display module works. But the second display stays black and the SD card won't get recognized.
Any further advice?
2023-7-15
DJI Gamora
fansb421f517 Posted at 7-15 12:38
Any further advice?
Hi, fansb421f517. Thank you for reaching out. May we ask about the specific model you're pertaining to?
2023-7-16
fansb421f517
DJI Gamora Posted at 7-16 19:12
An Action 2, bought in 2021. After I updated the firmware, the display module stays black and the SD card doesn't work.
2023-7-17
djiuser_pkEgQf5MfERC
Singapore
Did you try charging it?
2023-7-17
fansb421f517
Yes, it's full. I cleaned the contacts, charged it up and tried different SD cards and also without one.
It's exactly like in the video in the first post. The camera does recognize the second battery, but not the display nor the sd card. It's showing the animation when removing it from the camera, but it doesn't show an image when connected to it.
I know I have to swipe over the modules display to activate it. If I do this, the main display actually gets locked, but the modules display doesn't activate. So the touchscreen kinda works, but the display doesn't.
2023-7-17
hvanoorschot76
fansb421f517 Posted at 7-17 08:22
I had the same yesterday, but got a black screen on the camera module; just bought the camera on Amazon last week. It seems they shipped me an old unit, since the firmware is still at like 1.00.00.00 and MIMO app hasn't give me any update so far...
The battery unit front screen was working. Had to try and start the unit couple of times. Sometimes seems the on/off button doesn't work properly as well; not sure how long you should press it to get it working properly right away. Then both screens stay black but the green light is blinking.
My camera has the magnetic cover.
So far I find my experience with this unit is a bit disappointing.
I hope it will work properly on my holidays next week!
2023-7-17
djiuser_BJzmWlqsczeN
Brazil
I have the power module, and it also doesn't recognize the SD card anymore (it did in the past and worked perfectly for a couple of weeks.)
Not sure if a firmware update would fix this, or if I should send the unit for repair.
2023-7-18
@DJI any chance to re-apply firmware again. Seems there is a problem with the firmware update process. I bought a new one weeks ago and updated the firmware and it seems okay. Re-applying the firmware might fix it but i do not see any option.
2023-7-18
Firmware Ver
01.04.06.20
Camera Firmware Ver
10.00.36.21
Front touch screen firmware version
01.00.01.56
My working firmware. might be useful to check for comparison.
Can be found on settings in device info
2023-7-18
DJI Gamora
fansb421f517 Posted at 7-17 05:49
Thank you for the reply, fansb421f517. Can you please provide us a video of operation for further checking? Thank you.
2023-7-19
fansb421f517
DJI Gamora Posted at 7-19 06:30
It was the exact same as in the video in post #1.
After contacting the supoort, I sent it in for repair.
2023-7-20
DJI Gamora
fansb421f517 Posted at 7-20 09:01
Thank you for the update, fansb421f517. Please wait for the Damage Assessment that will be conducted in our facility and hopefully, you'll get your device as soon as possible.
2023-7-21
fifpep123
hi,
i have the excact same problem. how did you guys fix it?
3-26 10:10
DJI Paladin
fifpep123 Posted at 3-26 10:10
hi,
Hi there. Thank you for reaching out and we do apologize for the inconvenience. Please confirm what specific DJI product you are using. Also, please upload a short video showing the issue via Google Drive and send the link to us via PM so we can check the issue further. Please keep us posted.
3-28 03:22
