NTRIP Server without internet connection
1626 28 2023-7-7
auro
Brazil
Hi everyone, I currently own a DJI Agras T40.  I built an ntrip server at home using standard GNSS. I access my server through the control/joystick of the T40 creating an access point in my house. However, I can't see the rtk corrections coming to the controller when I don't have internet access. It seems to me that the control is performing DNS queries using the same interface to access NTRIP servers.  Is it possible to receive rtk corrections via ntrip using a local network without internet?  Is it possible to disable these DNS requests before sending the GET to the server?
2023-7-7
DJI Wanda
Hello, there. Sorry for the inconvenience. We will consult with our engineers and reply to you later.
2023-7-7
auro
Brazil
Thank you.
To elucidate:
So, if these DNS queries cannot be resolved, the RTK cant connect, even if the internet connectis isn't necessary.
What is my case, since my network is local and the bases are sending corrections normally through it, but the control interface simply does not send the command to receive the corrections while the DNS queries are not resolved and triggers a "Network error" .
After DNS resolved(with my access point in internet), i can listen the GET:
Auro.
2023-7-10
auro
Brazil
Using DJI Pilot 2 and the firmware of remote controller  02.00.0407, everything runs smoothly, I can stream corrections over my local network ans fix the mavic in the air.
The problem is only with the DJI Agras app, with firmware 01.01.0714 of remote controller and version of app 6.4.9.
2023-7-10
DJI Wanda
auro Posted at 7-10 11:29
Hello, sorry for the late response. Our engineers would like to have Custom- APP Logs and Custom - Remote Controller Logs when you tested.
It requires you to tell us the test time, as detailed as possible to the point of hours and minutes.
2023-7-12
auro
Brazil
Thanks for the response.
Follow the logs, the timestamp is already on the name files. LOGS
I can reproduce that problem every time I tested. Seems to me that is invariant over time.
Updating:
I wrote a dummy local dns server that resolves queries, including those of the CNAME type, and even so I could not receive RTK corrections without internet.
Observing the exchanged packets when there is internet, it seems that the RC/APP resolves these DNS and performs a series of synchronizations with the DJI server issuing an encrypted message "Client Hello" and then "Server Hello" comes from the servers, when this series of exchanges take place, then it is possible to join the local ntrip network and fix the T40 drone.
But in a situation with 100% no internet, such as operating the T40 in a deep forest, the local network set up in this environment cannot even receive requests from the drone. It seems to me that there is a logic in the software that requires synchronization with the servers to be able to establish an NTRIP connection, be it online or offline.
In other words, I need internet for a short period of time to sync and then later I can log into my local network to fix the T40.
2023-7-12
auro
Brazil
Sorry the link was wrong, follow the correct one: https://drive.google.com/file/d/1s5hb0_M4TFIH22eDY1s5kz8t-JoA2XEj/view?usp=sharing
2023-7-12
auro
Brazil
A smaller log that I measured the exact time of execution: https://drive.google.com/file/d/18pe8u6V6tbGkZPLWFwJLLPdmhLO-Vz1h/view?usp=sharing
The test was executed in 08:43 to 08:49 (UTC-03:00) approx. Using Shenzhen time (UTC+08:00)  is 19:43 to 19:49.
Auro.
2023-7-13
auro
Brazil
Any update?
2023-8-24
DJI Wanda
Hello, there. We are deeply sorry for the miss.
We can not receive the notifications unless you reply to us directly by clicking the REPLY button.
Your issue has been forwarded to our engineers. I will urge them to expedite the process first.
2023-8-25
djiuser_dw0q29zolsy7
Flight distance : 56923 ft
Brazil
DJI Wanda Posted at 8-25 04:49
Any update?
I have the same problem
2023-9-15
DJI Wanda
djiuser_dw0q29zolsy7 Posted at 9-15 01:19
Any update?
Hello, there. Currently, we did not receive the update. If you have the same issue, you may contact your dealer for troubleshooting first.
2023-9-16
DJI Wanda
Hello, there. Sorry for the late response.
Our engineers are struggling with reproducing the issue now.
They would like to have the APP Logs of DJI Pilot 2 for analysis. By doing this, they can compare the Logs with those of the AGRAS APP and dig further into the issue.
2023-9-18
auro
Brazil
DJI Wanda Posted at 9-18 03:18
Thank you for your response.
Yesterday I fly the Mavic 3M with DJI PILOT 2 version V6.1.1.1 with a local NTRIP without any access with internet, my drone flying fixed in rtk mode without any problem.
Follow the log:
https://drive.google.com/file/d/ ... FC/view?usp=sharing
Sorry for the late response too.
2023-10-11
DJI Wanda
auro Posted at 10-11 11:13
Thank you for your response. We have forwarded it to our engineers.
2023-10-11
djiuser_pZIIZKdmU9XV
Brazil
Hi!
I have same problem. Please, a quick solition!
2023-10-16
Brazil
DJI Wanda Posted at 10-11 20:13
Please. We need the solution.
2023-10-16
DJI Wanda
djiuser_pZIIZKdmU9XV Posted at 10-16 06:43
Hello, there. Sorry for the inconvenience. The issue of the OP might be different from yours. Would you please tell us more details about your issue?
2023-10-16
auro
Brazil
Any update?
2023-11-13
auro
Brazil
Iam still cannot fly rtk fixed mode with my T40 in no internet scenarios...
2023-11-23
DJI Wanda
auro Posted at 11-23 12:21
Sorry for the inconvenience. May we know if you tested with different SIM cards?
2023-11-24
DJI Wanda
Hi, Our engineers said, that from the data, we can see that the APP did not connect to the custom server you set. Please check whether the server is set up correctly. We also tried to reproduce the issue on-site but could not find the issue.
2023-11-25
auro
Brazil
DJI Wanda Posted at 11-24 01:21
I dont have SIM CARD, because in my flight areas there is no internet coverage, as I said earlier. My point is connect to a local ntrip server without internet and this includes without SIM CARD.
I only have this problem with agras, with the mavic this problem doest not occur.
2023-11-27
auro
Brazil
DJI Wanda Posted at 11-25 03:50
100% sure the data is correct, even  because, when I sincronize my account with DJI servers using DJI AGRAS APP, with the same NTRIP credentials I have the connection.
The question is: Its possible using NTRIP without internet in DJI AGRAS? Even the local ntrip server working well?
2023-11-27
DJI Wanda
auro Posted at 11-27 09:13
Sorry for the late response. We will ask them for further confirmation. Thank you for your update and feedback.
2023-12-1
DJI Wanda
Update: The current DJI Agras App will check the connection to the DJI official website. If the PING does not connect to the DJI website, the app will not enable internet RTK services.
We will improve it in the later version. Temporarily, please connect your remote controller to the outer internet and connect to the DJI website.
2023-12-5
auro
Brazil
DJI Wanda Posted at 12-5 03:50
Hello, thank you for your response, clarified a lot... I will look forward to this important update.
One last question: This "PING" is an ICMP normal packet or an customized message, like an HTTPS message?
2023-12-6
DJI Wanda
auro Posted at 12-6 05:45
PING means: ping dji.com
If the router can connect to the outer internet, then the function can be used normally.
2023-12-7
djiuser_2GjpEHwXEAcN
Brazil
auro Posted at 2023-11-27 09:13
Hi how are you, I have the same problem NTRIP without internet access doesn't work, I need to connect to Wi-Fi with internet access then I can connect to the base and the T40 works, but for places without internet access there is no way to use it, I am very disappointed with this product .
3-4 02:30
