Mavic 3T sensor specification? More details?
1341 9 2023-7-10
NEO-drone
Sweden
Trying to find out more about the 3T and the sensor and if it's worth upgrading from 2T.
For 3T I can only find that they list it as:
  • Video Resolution 640×512@30fps
But that's not really the same as sensor resolution. I mean, the sensor can be 4x3 pixels and still record in upscaled 640x512.
For 2T they listed it in more details like:
  • Sensor Resolution 160×120
  • Video Recording Modes 640×360 @8.7fps
So, have anyone found more detaild specifications of the sensor in question?
Cheers and thanks
2023-7-10
NEO-drone
Sweden
Or was the Enterprise and Enterprise Advanced two different models?
2 enterprise specs, here Sensor Resolution listed as 160x120:
https://www.dji.com/se/mavic-2-enterprise/specs
And here 2 enterprise advanced with that listed Sensor Resolution of  640×512 @30Hz
https://enterprise.dji.com/mavic-2-enterprise-advanced/specs
2023-7-10
NEO-drone
Sweden
Ah, Yes. So apparently they are different. So, then the Q is... Is it worth upgrading from M2EA to M3T?
2023-7-10
DRONE-flies-YOU!
Flight distance : 1638323 ft
NEO-drone Posted at 7-10 10:28
Yes, I think it is. First off, you get REAL zoom in the form of the 7x camera.
Second, the microbolometer (the thermal sensor) is improved via a smaller pixel pitch AND lower NETD. This makes for a sharper image and easier to detect living things against the background.
Third, the flight characteristics, safety systems, PSDK options, and controller are all improved.
Lastly, battery life is tremendously improved.
All that said, though, DJI has been dragging butt on unlocking all the "basic" drone functions like tracking and all the others that are mentioned in other threads. So that sorta sucks, but that's been their business model from the start.
2023-7-10
DJI Gamora
Hi, NEO-drone. Thank you for reaching out. The Mavic 3T sensor parameters are better than M2ED, Mavic 3T Sensor Resolution is 640×512, but M2ED only has 160×120.
2023-7-12
NEO-drone
Sweden
DJI Gamora Posted at 7-12 01:54
And compared to M2EA?
2023-7-12
DJI Gamora
NEO-drone Posted at 7-12 02:34
M2EA has the following sensor details:
Sensor size:7.68mm x 6.144mm
Pixel size:12μm
Sensor Resolution:640×512
Photo resolution:640×512
Video Resolution:640×512@30fps
Focal Length:9.1mm
2023-7-17
NEO-drone
Sweden
DJI Gamora Posted at 7-17 07:34
And pixel pitch?
All the values you just posted is the same for 3T, right? But the pixel pitch differs? Do you have a value for the two?
Thanks again
2023-7-17
DJI Gamora
NEO-drone Posted at 7-17 07:42
And pixel pitch?
Hi there. The two of them have similar sensor specifications. Let me check if we have information for the pixel pitch. I'll get back to you once we receive details from our relevant team.
2023-7-18
NEO-drone
Sweden
Similar, but not identical? People are talking about another pixel pitch. Would be interesting to know in detail. But if there are no details more than "similar" I guess that an upgrade from M2EA to 3T just for the thermal isn't really recommended?
2023-7-18
