DJI RC N1- Not turning on not charging
7324 24 2023-7-15
ioanniskr
Flight distance : 571165 ft
Greece
I own the DJI Mini 3 Pro and today the DJI RC N1 remote stopped functioning mid flight, I got a black and white screen on the mobile phone.
Fortunately the Return Home function kicked in and the drone came back. The remote controller does not charge or turn on, no LED light is on or flashing.
When I returned home I pressed the power button for one second, then again, hold it to power the remote controller on, nothing happened.
I tried to charge it with two different chargers and two different cables, nothing happened, none of the LEDs turned on.
I downloaded the flight log from the mobile and the last message was: RC not connected to mobile device.
I am running the v1.10.6 DJI Fly app and both the drone and controller have the latest firmware.
Any ideas what to do?
2023-7-15
DJI Gamora
Hi, ioanniskr. Thank you for reaching out. Please try the steps below (feel free to skip the steps which you already performed):
1. Check whether the battery level has reached 100% (All four bars of the battery level indicator are on).
2. Check if the charged method is correct. Make sure the charging cable is plugged in tightly, and try plugging it in again.
3. Check the LED on the remote controller and confirm if it is in the charging state. If yes, please try charging for 2 hours to see if the power increases. If it still cannot charge, it is recommended to replace the charger and charging cable.
If the charging continues to fail, please provide us with a video showing the issue. Please keep us posted.
2023-7-15
ioanniskr
Greece
DJI Gamora Posted at 7-15 17:12
Hi! I tried all of the steps you suggest but the remote controller is completely unresponsive/ dead.
No LED lights up when pressing the Power On button or when connecting a charger, so I can't see the battery level or if it's in charging state. As I mentioned in my first post I tried charging it with two different chargers/ cables with no result.
2023-7-15
ioanniskr
Greece
2023-7-15
DJI Gamora
ioanniskr Posted at 7-15 22:55
https://youtu.be/_aflvESN7S0
Hi ioanniskr. Thank you for the update. In this kind of situation, I'm afraid that you may consider sending the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support). Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your understanding and support.
2023-7-16
Travis Gosnell
Flight distance : 92 ft
DJI Gamora Posted at 7-16 19:22
Hello,
I just bought my DJI mini 3 pro.. own for 5 days..
Test flight worked well..
Charged all devices. Flew to Hawaii to use the drone on vacation... Charged all devices after arriving to Hawaii..Launched the drone , within 10 mins controller turned off, drone returned (thank goodness) but the controller is dead.. no battery indicator lights, nothing happens...
Will not turn on.
The temperature outside was 85° Fahrenheit.
Tried all things above in this post.
What is the next option?
2023-10-22
djiuser_kRlRmMI3SJGq
Philippines
Hi sir/mam good day, i am one of dji mini 2 drone user, i have encoutered not functioning or not able to charge my controller, i dont know what happens, no green leds light. Please advise what shoud we do here to fix this issue.
Thanks
2023-11-15
DJI Tony
djiuser_kRlRmMI3SJGq Posted at 11-15 03:14
Thanks
Hello there. Thank you for reaching out. Have you already tried DJI Gamora's suggestion in reply 2#?
2023-11-15
DJI Gamora
Travis Gosnell Posted at 10-22 11:19
Hello,
Hello, there. We're sorry for the late notice. Please know that it's recommended to send your remote controller for proper inspection and repair. If you wish to get the remote controller in service, you may use this link. Rest assured your case will be handled accordingly.
2023-12-4
gkm
India
I am eager to know how did you resolve the issue.
1-21 02:17
gkm
India
I am having identically same issue. When we updated the software the issue poped up and now no charger seems to bring the RC back to life.
1-21 02:19
gkm
India
Travis Gosnell Posted at 2023-10-22 11:19
Hello,
Hi
I am in identical situation , can you help if we can do any further diagnostics , I am in India and afraid could not locate any service centre here .
2-12 07:36
gkm
India
DJI Gamora Posted at 2023-7-16 19:22
Hi
2-12 07:38
DJI Gamora
gkm@gtsindia.co Posted at 2-12 07:38
Hi
Hello, there. Sorry for the trouble that it may cause you. May I confirm if you managed to follow the recommendations provided in post #2? You may also try to connect and download the DJI Assistant 2 via this link. After the installation, you may connect your remote controller and refresh/update the firmware. However, if the situation remains, you may contact your dealer for further assistance. Thank you for your understanding.
2-16 00:16
djiuser_2H9LhDVKxj6o
Same!
Flown 3 times
RC Smart controller
-will not charge,
-LED's will not light
-Will not charge
multiple cords tried
pushed button for 15 sec
pushed for 1 sec then long holdCannot connect with DJI Assistant 2 because it is dead.
All with no response!
What shal I do now??
2-16 17:37
DJI Paladin
Flight distance : 318 ft
Hi there. We sincerely apologize for the inconvenience caused. Can you please confirm what specific RC controller are you using? Could you please provide us the serial number via PM so we can check it further? Also, have you tried to leave the RC on the charger for approximately 2-3 hours or more to check if the behavior is still the same? Please keep us posted. Thank you for your cooperation.
2-16 23:56
plakiwe
Togo
same problem for ; i try all solution -
has anyone have solution ?
3-20 09:23
tobysearchfield
Flight distance : 46283 ft
6-7 06:25
ssjwiggy
Flight distance : 14416 ft
Bumping this thread. I've taken my DJI 2 mini on a total of 4 flights and my controller won't stay turned on while plugged into a USB-C charger. DJI still hasn't acknowledged that this is a widespread issue. Are we at least able to get these fault controllers repaired for free?
8-14 21:08
Strtdrmr
Flight distance : 40899 ft
The same exact thing happened to me mid flight. No warnings or indication that the battery on the remote was about to die. Luckily the drone returned home on its own. What's the source of this issue. It's obviously not an isolated incident.
8-25 07:12
ssjwiggy
@DJI Natalia
Here's another user having the exact same issues as me and many others.
8-29 05:41
djiuser_bL5vnjwnmIQP
Bangladesh
After the update, I have flown my drone. After 30 seconds, remote controller stopped and thats it. Drone came down and after that, controller is not responding.
Everyone has the exact same issue. Interesting
9-16 05:04
DJI Diana
Flight distance : 2408 ft
djiuser_bL5vnjwnmIQP Posted at 9-16 05:04
Hi there,
thank you for reaching out.
We apologize for the inconvenience. Can you confirm if you received an error message too?
9-16 21:49
auahglapp
Flight distance : 44875 ft
Indonesia
Hi, bump up this thread again since just got the same problem a couple days ago, and to send to service center here in Indonesia will be a big problem and since this is the same issue as others please inform us the solutio rather than only send it to any service center. thanks
10-21 18:19
djiuser_AojwgR9kEOV3
South Africa
How can so many people have the same issue and DJI just brushes it off giving silly troubleshooting options as if we all didn't desperately try everything we could find on the internet.
PLEASE EMAIL ME if this has happened to you and together we can possibly do something because I feel so cheated to have to pay for an assessment and then the replacement of the controller when the fault was not mine.
My email: rjdeleca@gmail.com
10-30 11:38
