Battery is full but not recognized
1396 28 2023-7-16
Paul Lenz
Flight distance : 3740 ft
One of my 3 batteries is full (4 green LEDs) and provides the drone with energy, I hear the start melody, I see the picture from the camera on my mobile phone, I can zoom and move the camera - but all 4 LEDs of the drone are red and the remote control gets no information about the battery status. It thinks the battery is empty and it is not possible to start flying. What is wrong? The 2 other batteries are working as usual.
2023-7-16
DJI Tony
Hi, Paul Lenz. Are you getting any error messages from your screen?
2023-7-16
Paul Lenz
DJI Tony Posted at 7-16 21:51
Not really. When a connection between the drone and the remote control is established, there is a message in red letters "battery is nearly empty, fly home ASAP" or similar. But the battery level is not "0%", it is "--". I also can not get information about the number of charges or the voltage of every cell.
2023-7-16
DJI Tony
Paul Lenz Posted at 7-16 21:57
Are your devices on the latest firmware? Please try to refresh or upgrade it using the DJI Assistant 2. You can download it from here. Can you also submit a screenshot of what you're seeing on your end so I can submit it to our designated team if ever we need to?
2023-7-16
Paul Lenz
DJI Tony Posted at 7-16 22:24
Everything is latest firmware. Today there was an update, but only regarding flight zones.
2023-7-16
DJI Tony
Paul Lenz Posted at 7-16 23:24
[view_image]
Thank you very much. I will get this referred to our designated team. I will get back to you fast. I appreciate your patience by the way.
2023-7-16
Sean-bumble-bee
Flight distance : 15997 ft
If needed use a magnifying glass and check that the contacts on the battery are are clean and clear of fluff etc..
2023-7-16
DJI Tony
[view_image]
Thank you for waiting. We recommend wiping the metal contact pins on the battery (as also advised by Sean-bumble-bee) with alcohol (concentration >= 75%) and retrying. Turn on the battery and leave it for a while to discharge, then charge it again to test. If the above steps do not work, it may be due to the battery cell error, we suggest using another battery. Can you also DM me the serial number of the drone for further checking? Thank you.
2023-7-17
Paul Lenz
DJI Tony Posted at 7-17 00:36
OK, I tried to clean the contacts, but without result as expected.
Sure, I have to use another battery, that's quite logical. But do you really think that I have to throw this expensive and actually well working battery away?
I write you the SN in a Personal Message.
2023-7-17
DJI Tony
Paul Lenz Posted at 7-17 01:55
Sorry, Paul. I completely understand you. It's not that easy to throw away an item that is valuable but seems like the troubleshooting was already done and it did not fix it. There's a high probability that it's a battery cell error and it can't be repaired. Hopefully, you get some advice from your co-pilots. Thank you for your understanding and support. Have a great day ahead.
2023-7-17
Sean-bumble-bee
A few other suggestions,
1) do you have the USB adapter that allows the battery to be used as a power source for USB? If so what happens if you connect that to the battery switch the battery on and try to charge something with it?
2) post a good photograph of the entire connector on the wonky battery, showing all the contacts and the dividers between them.
3) if you have a multimeter that has very fine probes, check what voltages etc. are seen between the various pairs of contacts in that connector. BUT YOU WOULD NEED TO GOOGLE THIS, both in relation to which pairs of terminals/contact you should test and, what results you should see. That might be a question for a more technically orientated forum than this one e.g. Git hub or something like that, I doubt the Mods here would be allowed to release such information. I have seen pinouts for the connector, in fact I think the car charger shows a pin out but I do not know what you should see. Some of the connections presumably transfer data rather than simple voltages and power.
2023-7-17
Paul Lenz
Sean-bumble-bee Posted at 7-17 03:19
I don't have that adapter, but I am absolutely sure it would work. The battery provides the drone with power, I hear the start melody, I see the picture from the camera on my screen, and I can even zoom and move the camera. I can do everything except take off.
That's why I doubt that there is a cell error.
I hope this photo shows what you want to see. The left 4 pins are (+), the right 4 pins are (-). The 2 pins in the middle seem to transport data.
2023-7-17
Paul Lenz
There seems to be much to learn. The pins in the middle are SDA and SCL for communication.
2023-7-17
Paul Lenz
DJI Tony Posted at 7-17 02:43
Hi Tony,
I succeeded to check the pins in the middle with an oscilloscope. I found out that there is a bunch of pulses every second if I use a working battery. But there are no pulses if I use the battery I am talking about. That means, all battery cells are OK, but a chip for communication is out of order. And I am afraid, this can not be repaired
2023-7-17
Sean-bumble-bee
Paul Lenz Posted at 7-17 12:50
Hi Tony,
It's good that you found out what should be there but a pity it's not working.
Might it be worth opening the case and having a look at the solder joints etc.. for the signal wires.
The dodgy bit is you'd need to work with the board 'live', if you disconnect the main power I think the ''gas gauge'' or something like that, switches to open circuit and that is effectively the end of the battery unless you can reset the 'whatever'.
It might be better to discharge the battery somewhat if you attempt that, I wonder if it will self discharge?
2023-7-17
DJI Tony
Hi Tony,
Sorry to hear that. Though we don't recommend repairing the battery on your own but hopefully you can get some good advice from your co-pilots.
2023-7-17
Paul Lenz
DJI Tony Posted at 7-17 22:08
Don't worry. I think I will keep this battery for other projects where I need a powerful source for more than 12 Volt.
In one Facebook group I got the advice to contact DJI support. To be honest, I doubt that the DJI suppport will help me, or what do you think? For which reason you asked me for the serial number?
2023-7-18
MaCJaX
Flight distance : 444193 ft
Get a CP2112 and re-flash the firmware to it. There's youtube videos on how to do it. The CP2112 is only $10.
2023-7-18
DJI Tony
Paul Lenz Posted at 7-18 11:29
Yes. It's a good idea to contact our support for a second opinion. Please go to this link to get some assistance with them. I asked for the serial number of the battery to confirm if it's an official DJI battery and if we can get that replaced using the manufacturing warranty however it's already out of the warranty period.
2023-7-18
Paul Lenz
DJI Tony Posted at 7-18 19:57
Thank you very much for this link. But what should I click? Repair requerst, Exchange service, or what?
2023-7-19
DJI Tony
Paul Lenz Posted at 7-19 03:54
Sorry for not giving enough details. Scroll down until you see "Contact us". You can select either online support via chat or "Hotline Service". There should be a list of numbers you can call (if you're in Germany:
+49 (0) 9771-906 990). Just to give you a heads-up, the battery is already out of warranty but you can check with them if you want further help.
2023-7-19
Paul Lenz
MaCJaX Posted at 7-18 19:12
I am afraid to bother with a dead horse (and that's also why I hesitate to call the support).
Between + and -, there are 2 pins named SCL and SDA. Both pins show a lot of pulses if I use a battery which is OK. If I connect the battery I am talking about, SDA has constant 3.3 Volt and SCL has constant 1,0 Volt.
Especially the last value is irritating, it should always be 0,0 Volt or 3,3 Volt, nothing else.
That's why I suppose, that something is seriously broken.
2023-7-19
Sean-bumble-bee
Could you post a link please?
Doesn't matter, one was easier to find than I imagined it might be.
2023-7-19
MaCJaX
Sean-bumble-bee Posted at 7-19 09:00
Sure,
Here is an Amazon link for the CP2112. It's a little cheaper on eBay but it ships from China. I know you're in the UK so you might want to search for this on UK eBay:
https://www.amazon.com/Teyleten- ... ps%2C479&sr=8-4
Check this video out on how to access the battery with the CP2112:
2023-7-19
Sean-bumble-bee
MaCJaX Posted at 7-19 14:29
Sure,
Many thanks.
2023-7-19
Paul Lenz
DJI Tony Posted at 7-19 04:23
I tried, but they don't want to help because the battery is from 2019.
2023-7-20
Paul Lenz
I installed the DJI assistant and refreshed the drone firmware. The program worked until 82%, then it gave the message "Battery update error" and stopped refreshing.
So I am sure, also a CP2112 would not help.
2023-7-20
DJI Tony
Paul Lenz Posted at 7-20 01:46
Sorry to hear that. We are more than glad to help you, however since the battery is already out of warranty, we cannot get it replaced. Thank you for understanding
2023-7-20
MaCJaX
Paul Lenz Posted at 7-20 01:51
Yea, I agree. It sounds like the battery is defective.
2023-7-21
