Air 2S Obstacle Avoidance
1654 8 2023-7-17
fans915ba0ce
My Air 2S has OA top-bottom front-rear, but not sides.  So if it's set to go around obstacles, how does it avoid side collisions?  I can envision it changing heading so it has a better chance of detecting objects, but still seems to be an exposure.  In practice how does it work?  And is it "smart" enough to change altitude if it can't find a path?
2023-7-17
DJI Tony
Hi, after enabling "Bypass", the aircraft will automatically change and plan a new flight path to bypass the obstacle and detect an obstacle. If the obstacle cannot be bypassed, the aircraft will hover in place. And as you have mentioned, this model does not have a sideway obstacle avoidance function, so there will be more risk of crashing, and by the way, APAS is just an auxiliary function. We don't recommend being dependent on it. It is advised to manually control the aircraft and check the App prompt during the flight. Have a great day ahead.
2023-7-18
fateofangel
Flight distance : 1397238 ft
Poland
Air 3s or Air3 will robably have side to side sensors which will be the game changer
2023-7-18
fans915ba0ce
DJI Tony Posted at 7-18 00:59
Thanks for the reply, but you haven't told me anything I don't already know.  When the aircraft plans a path around the obstacle, does it re-orient the heading or just "crab" sideways?  I can see some measure of protection if it changes heading, so that it can sense other obstacles to the side of the original.  And I know, probably the best way to answer my question is to set up an experiment, and watch what maneuver is used.
2023-7-18
djiuser_21vazN53a4oJ
Flight distance : 542431 ft
There should be an option to disable sideways flight probably for this excact scenario, if they haven't removed it.
2023-7-18
fans915ba0ce
djiuser_21vazN53a4oJ Posted at 7-18 05:53
I believe that disables the right control stick horizontal movements, so that one cannot fly the drone sideways.  I haven't seen anything that would lead me to believe it works for autonomous flight.
2023-7-18
DJI Tony
fans915ba0ce Posted at 7-18 05:28
Yes. The aircraft will avoid obstacles by flying above, below, or to the left or right depending on the flight environment with the help of APAS 4.0.
2023-7-18
fans915ba0ce Posted at 7-18 09:35
By the options name one might suggest it disables sideways flight no matter the flight mode. If I remember correctly it did for my Air 2S. If you are skeptical about it, try it in an open field.
2023-7-19
Shawgod
Flight distance : 5173104 ft
I fly at a tree farm frequently and it has to avoid obstacles frequently.  It will use the front sensors when flying forward to turn to the right or left  if flying forward.  If you have sideways flying off, it will just stop.
2023-7-30
