DJI Gamora
Pocho35 AR Posted at 7-19 15:01
Yes, I also have a mini SE that I bought when
the mini 1 failed, and so far it works fine. From time to time I test the mini 1 and a few days ago it connected normally, and I used it in a short and low flight doing it normally, I turned it off, I kept very happy for the return to normal , but it did not last long, the next day, it failed again...
Thank you
Hi, Pocho35 AR. Thank you for the reply. When the aircraft status indicator blinks red and green alternatively, it indicates that the drone is in GPS mode. If the motor can be turned on, the drone is in the Altitude zone/Warning zone. If the motor cannot be turned on, the drone is in a Restricted zone.
For the issue with the RC, can you please provide the error on the DJI Fly? If you could also provide a video showing the issue, that will be much appreciated. Thank you. |
