patiam
Flight distance : 1156358 ft
tareqkun Posted at 7-20 07:48
Thanks patiam, your thorough explanation is really helpful! I am new to the world of drones, and gladly I am learning new things every day, I learn the most from my mistakes (although I wish I was born with this knowledge already! ) and from the help I get from experts like you who are willing to share their knowledge and experience. For some reason (maybe influenced by the seller) I thought the D-RTK2 already knows where it is located, just like a GPS, thus there is no need to any user input, and it communicates with the RTK on the drone to tell it where it is, not only in relation to the ground station, but also on the globe. Thank you again, that's is extremely helpful, and I will do this in my next mission in few days.
You're very welcome.
Drones are already a learning curve w/o adding precision GNSS into the mix, so good luck!
To calirify- the D-RTK does know where it is, as it is a GNSS unit- it just doesn't know precisely enough to generate corrections for the drone that will be survey-grade accurate unless you tell it, or provide corrections to it from another source. The concept is Differential Correction. The base station compares its independently computed position to the precisely known one you have provided it, and determines the difference (offset) in XY&Z, and send that to the drone. Without the precisely known position, the base has nothing to compare to, so the corrections it sends are not as good.
