New DJI Dock Firmware Released (02/22/2024)
3063 2 2023-7-18
DJI Support
Flight distance : 2408 ft
China
Overview
  • Date: 2024.02.22
  • Dock Firmware: V01.06.1704*
  • Aircraft Firmware: V09.01.0006*
  • Intelligent Flight Battery: V02.00.20.58
  • Remote Controller Firmware: V03.02.0907*
  • DJI Pilot 2 App: V9.1.0.21
  • DJI Assistant 2 (Enterprise Series): V2.1.12
  • Firmware Update Method
  • DJI Dock: DJI FlightHub 2 / DJI Assistant 2
  • Aircraft: DJI FlightHub 2 / DJI Assistant 2 / App
  • Remote Controller: DJI Assistant 2 / App
  • The built-in DJI Pilot 2 App: will be updated with the Remote Controller firmware
* Make sure to update the firmware version for the aircraft, the remote controller, and the dock. Otherwise, they will not be compatible with each other.
What’s new
DJI Dock
  • Added support for Trial Flight. Users can assess the task performance and media file transfer performance after completing dock configuration.
  • Added support for Silent Mode. In Silent Mode, the operation noise will be reduced and the cooling performance of the air conditioning system will be affected.
  • Added support for enabling obstacle data settings to improve flight safety. Go to the DJI FlightHub 2 User Guide and refer to the Map Task Area section for more information.
  • Added support for transferring and managing the unlocking licenses and updating flight safety database in DJI FlightHub 2.
  • Optimized functions in DJI FlightHub 2. Refer to the DJI FlightHub 2 Release Note for more information.
Notes:
To ensure safe use and efficient operation, it is recommended to visit the links below for a comprehensive understanding on safety and product information:
Overview
  • Date: 2023.12.28
  • Dock Firmware: V01.05.0908*
  • Aircraft Firmware: V09.00.0503*
  • Remote Controller Firmware: V02.02.0803*
  • DJI Pilot 2 App: V9.0.5.39
What's new
Matrice 30 Series Dock Version aircraft
  • Fixed some minor bugs.
  • Added some functions to meet local regulation requirements.
Notes
Overview
  • Date: 2023.11.23
  • Dock Firmware: V01.05.0905*
  • Aircraft Firmware: V08.00.0003*
  • Remote Controller Firmware: V02.02.0405*
  • DJI Pilot 2 App: V7.1.0.32
  • DJI Assistant 2 (Enterprise Series): V2.1.11
What’s new
DJI Dock
  • Fixed an occasional error prompt related to the air conditioning system's heater.
Notes
Overview
  • Date: 2023.10.12
  • Dock Firmware: V01.05.0902*
  • * Make sure to update the firmware version for the aircraft, the remote controller, and the dock. Otherwise, they will not be compatible with each other.
What’s new
  • Matrice 30 Series Dock Version aircraft
  • Improved aircraft flight stability.
Notes
Overview:
  • Date: 2023.09.18
  • Aircraft Firmware: V07.01.0026*
  • DJI Dock: DJI FlightHub 2 / DJI Assistant 2Aircraft: DJI FlightHub 2 / DJI Assistant 2 / App
What’s new
DJI Dock
  • Updated the RTH to Advanced RTH.
  • Optimized battery safety strategy. The dock cannot perform Continuous or Timed tasks if the battery cycle count exceeds 500 cycles. Immediate tasks and FlyTo tasks will not be affected.
  • Added support to stop the flight route task after pressing the emergency stop button when the dock is preparing for the flight route task.
  • Optimized the operation logic of the air conditioning system to reduce the fan noise when the air conditioning system is idle.
DJI FlightHub 2
  • Added support for the aircraft to bypass GEO Zones when performing FlyTo tasks or during RTH.
  • Added support to improve safety of RTH and safe Resume Task from Breakpoint. When editing the waypoints, the waypoint can be marked as a no-return point, and the flight route to its previous and next waypoints will be marked as a no-return area. The aircraft will fly along the flight route to exit the no-return area before performing RTH or Resume Flight from Breakpoint.
  • Added support for DJI AirSense to improve flight safety.
  • Added support to manage custom flight areas and GEO Zones in Flight Area Management, allowing for more flexible flight plans.
  • Added support to control PSDK payloads in DJI FlightHub 2.
  • Added support to set the palette, enable side-by-side view in the IR camera view, using RNG, and Face PinPoint in the livestream view after obtaining payload control.
  • Optimized the warning messages for emergencies such as alternate landing, incorrect landing locations, or unable to land on the dock.
DJI Pilot 2
  • Added warnings when configuring the dock in GEO zones.
  • Added support for site selection using the DJI Mavic 3 Enterprise Series aircraft when configuring the dock.
  • Added support to check the network connection for the dock.
Notes:
Overview:
  • Date: 2023.07.18
  • Dock Firmware: v01.04.0705*
  • Aircraft Firmware: v07.00.0146*
  • Intelligent Flight Battery: v02.00.20.58
  • Remote Controller Firmware: v01.02.0445*
  • DJI Pilot 2 App: v7.0.3.9
  • DJI Assistant 2 (Enterprise Series): v2.1.10
  • Firmware Update Method DJI Dock: DJI FlightHub 2 / DJI Assistant 2
What’s new
DJI Dock
  • Added support to reset standard maintenance count for the dock in DJI Pilot 2.
  • Optimized the RTH logic in strong wind conditions. The aircraft will return to home if the wind speed is too high.
Notes:
2023-7-18
djiuser_kGchYZnFF2er
Flight distance : 6184 ft
Updated the firmware this morning, instantly had issue with vision system.  Have attempted recalibration a dozen times and the calibration fails every time.  Did not have an issue before the update.
2023-9-18
DJI Gamora
djiuser_kGchYZnFF2er Posted at 9-18 17:27
Hi, djiuser_kGchYZnFF2er. Thank you for reaching out and we're sorry for the inconvenience. Can you please provide us with a screenshot of the error message?
2023-10-2
