Video Issue
417 15 2023-7-18
Axolotl47
Folks,
I noticed recently that bright sky or white/bright surfaces show up striped in wobbly black and white lines on my iPhone monitor screen.
However, photographs taken do not have this distortion.
Is this effect normal? Or, is my camera experiencing an issue??
Best,
Jack
2023-7-18
DJI Gamora
Hi, Jack. Thank you for reaching out. May we ask what device are you pertaining to? Please provide us with sample files showing the issue as well. Thank you.
2023-7-18
djiuser_Utd1DsNSJwDE
Croatia
Hello. I have a mavic mini and after uploading the video and photos on my mobile (Samsung A32)  I was not able to read video anymore neither on my mobile or in the dji fly app. Whereas I was able to read them in low resolution before the uploading. The message is impossible to read the video. Thanks for your help
2023-7-19
djiuser_Utd1DsNSJwDE Posted at 7-19 01:45
Hi there, it may depend on your phone's limitations. If it does not support playing high-resolution videos, we recommend you export it to a computer for playing.
2023-7-19
Croatia
DJI Mindy Posted at 7-19 02:08
Thank you for your response. But I don't understand why I can't view the video stored in the drone as before the uploading. Moreover I was able to read video in the dji fly app before. Is there any change in the app since several weeks?
2023-7-19
DJI Wanda
djiuser_Utd1DsNSJwDE Posted at 7-19 06:37
Hello, there. May we know where did you view the video from? In the app, the album or SD card file?
Whether the video can be viewed on the phone is determined by whether the configuration of the phone can support it.
2023-7-20
Croatia
Hi. When I select my phone in the dji fly app, video are "black" and unreadable (see screenshots). When I select "my device" I can't see all the video and they're in low resolution. If I connect the drone and my phone, all video are unreadable. I think that the fact to upload the video in my phone prevents the reading of the video since they are not available in cache. What do you think?
2023-7-21
DJI Susan
djiuser_Utd1DsNSJwDE Posted at 7-21 04:55
Thank you for your additional information. Could you please clarify the upload action you referred to? Does it mean if you did not upload the video, the full resolution of the video can be viewed normally, yet, after you uploaded the video, the full resolution of the video can no longer be viewed in the app?
Please confirm it and tell us the DJI Fly app version you are using for better assistance, thank you.
2023-7-21
Belgium
DJI Susan Posted at 7-21 20:09
The version is 1.9.4
The action was to upload on the phone to have the full resolution. By doing this, I was not able to read the video directly on my phone, by the app in the folder saved or by the app on the folder device. Now I made some new video's and can view the old video's in low resolution again. It seems then to be a problem with my phone to read high resolution video's and probably the fact to have the same name in the folder dji album (high and low resolution videos). I had already done it before and it was working with the same phone. I don't know why it doesn't work this time.
2023-7-22
DJI Wanda
djiuser_Utd1DsNSJwDE Posted at 7-22 02:26
When you say read the video, do you mean display the thumbnail or display the video on your phone?
2023-7-23
Axolotl47
DJI Gamora Posted at 7-18 21:08
Thanks, DJIG,
This is a MAVIC 2SE. The phone is a iPhone 10.
I’ve attached a photo so you can see what I’m referring to.Hopefully, this helps?
Best,
Jack
Screen distortion
Screen distortion
2023-7-25
WN1X
Flight distance : 37884 ft
Those lines are caused by overexposure. Either use a faster shutter speed or switch the camera to auto from pro mode.
2023-7-25
DJI Gamora
Axolotl47 Posted at 7-25 03:48
Thanks, DJIG,
Hi, Jack. Thank you for the photo. Please disable the overexposure warning in the Camera Settings, like the image below:
2023-7-25
Axolotl47
Excellent. Will do!
Update: Done. Cured. Thanks a bunch!
2023-7-28
Axolotl47 Posted at 7-28 03:49
Excellent. Will do!
Thanks for the update. Glad to the issue is resolved. If there is anything else we can help you with, please feel free to contact us.
2023-7-29
DJI Gamora
Excellent. Will do!
You're most welcome, Jack. Glad that we were able to help. Have a safe flight always!
2023-7-31
