RoboMaster App Scratch to Python to Python IDE
1981 3 2023-7-20
MariusCologne
Hello all,
I would like to use the Line Follower method with the Robomaster. I want to implement this function with a script in Python. To do this, the first thing I did was to create the code in the RoboMaster app through Scratch programming. This can then be easily displayed in Python code. However, this Python code can not be implemented directly in PyCharm in my Python IDE. Do I need to install other packages than the Robomaster package?
Thank you already for your help!
2023-7-20
BGA
Robomaster code is designed to work only inside the robot. There is no easy way to try to use it outside it.
2023-7-20
MariusCologne
Thank you, Captain. Your answer saves me from further pointless searching for a solution. That means AI solutions via an own script can only be implemented if you implement the whole functionality yourself and functions like the line detection of the Robomaster can not be accessed?
2023-7-20
BGA
MariusCologne Posted at 7-20 14:07
It depends. If you have an EP, there is an external Python SDK that you can use. But it does not work on the S1 without a hack. It is different from the built-in SDK though so you can not use the code written for one with the other.
https://robomaster-dev.readthedocs.io/en/latest/
2023-7-22
