RC Pro & Air 2s toggling between video and photo
892 8 2023-7-23
Jlightfield
I would like to switch between the photo and video modes for the camera. The camera button the RC PRO controller does not seem to do that in flight. When not it will switch from video to photo but not back. Am I missing something obvious here?
2023-7-23
DJI Gamora
Hi, Jlightfield. Thank you for reaching out. Can you please provide the firmware version of the drone and RC Pro and the camera parameters for further checking? If you could also provide a screen recording/video showing the issue that will be much appreciated.
2023-7-23
sduck
Flight distance : 4315098 ft
I think you're asking if there's a way to make one of the customizable switches a dedicated still/video toggle - is this correct? I don't think this is possible - I can't find it as one of the options available. In DJI Fly, while connected to your drone, go to the controls section, near the bottom is a section where you can set what the various customizable switches do. None for camera mode unfortunately. Note that there are actually 6 shooting modes available.
2023-7-23
Mobilehomer
Flight distance : 18150351 ft
It takes two presses. One to change, the second to start recording/take picture.
2023-7-23
Jlightfield
DJI Gamora Posted at 7-23 10:09
the firmware is 02.04.2500 for the aircraft and 03.02.0400 fir the RC pro. I start in video mode in pro mode, and then press the camera button and it will switch to photo. Subsequently it will only take photos if i press once, or twice. It will not go back to video and i have to use the touchscreen.
thank you
2023-7-23
Jlightfield
sduck Posted at 7-23 13:20
Yes, on the regular RC I can toggle between video and photos with the camera button. It is not behaving the same way on the Pro RC.
2023-7-23
Mobilehomer
The left button is video, the right is photo on the RC Pro
2023-7-23
Jlightfield
Mobilehomer Posted at 7-23 18:50
Thank you, I knew i was missing something!
2023-7-24
DJI Gamora
Jlightfield Posted at 7-23 15:14
thank you
Thank you for the reply. It seems that Mobilehomer has provided the answer to your concern. If the issue persists, please let us know. Thank you.
2023-7-25
