M300 controller not connecting to wifi
1311 4 2023-7-24
VirtualGeol
Flight distance : 6770951 ft
Hi,
One of the controllers for our M300 has stopped connecting to the wifi. It sees the wifi and it says that it is connected but there is no data. I know this because I can't download maps or sync flight records
So far I have tried
1. Logging onto a different wifi - same problem
2. Logging on to phone hotspot - which also used to work.
3. Removing the wifi from the list and then reconnecting
Non of these issues seems to be able to fix it. I can connect fine with the other controller.
Does anyone have any suggestions
Thanks
John
2023-7-24
DJI Gamora
Hi, VirtualGeol. Thank you for reaching out and we're sorry for the inconvenience. Let me forward your concern to our relevant team for further checking. We'll get back to you once we receive an update.
2023-7-24
AR_AirPrecision
Flight distance : 2683589 ft
Belgium
Are you connected/supposed to a Cloud service like FlightHub? If so, disable it. I had in the past once an issue with that...no internet, turned off the FlightHub and it worked again.
Did you try a factory reset?
2023-7-27
VirtualGeol
AR_AirPrecision Posted at 7-27 04:19
Thanks for that. I disconnected FlightHub and installed a new update and it seems to have fixed it.
Much appreciated
John
2023-7-27
AR_AirPrecision
Belgium
VirtualGeol Posted at 7-27 05:00
Much appreciated
John
Top! If you reactivate FH it should keep working at least in our case.
@DJI : same issue as ticket#5014410
2023-7-27
