Flying in area with bad satellite signal
913 4 2023-8-2
djiuser_0wTyuQeXj3NE
Flight distance : 1652090 ft
Sweden
Hi!
I´m about to do a job that requires me to fly indoors where my drone might loose the satellite signal. I´ve heard (and experienced) drones flying into walls when they loose the signal.
My questions is:
1. What can I do to prevent this, cover/turn of sensors?
2. Wich drone is better suited, I owe a DJI mini 2, and a DJI mini 3.
2023-8-2
Blériot53
Flight distance : 6260935 ft
You may find this article useful :
https://cultofdrone.com/drone-at ... 0mode%20on%20these.
2023-8-2
Sweden
Blériot53 Posted at 8-2 07:20
https://cultofdrone.com/drone-atti-mode/#:~:text=Now%20a%20built%2Din%20feature,as%20A%20mode%20on%20these.
Thanks that helped!
2023-8-2
Blériot53
  Good news.
2023-8-2
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. It is not recommended to fly indoors unless special circumstances or necessary conditions are met because most DJI aircraft use GPS positioning. However, the indoor GPS signal is poor (and sometimes there is no GPS signal), which may affect the aircraft's positioning accuracy making the aircraft likely to drift and crash. Please make sure to check the aircraft vision system and infrared sensing system and related effect conditions to avoid any incident. If using the DJI Mini 2, you may visit the user manual and please start at page 16, if you use the DJI Mini 3, please visit the user manual and please start at page 17. Please fly with caution. Thank you for your understanding.
2023-8-2
