Actual flight time on the Air 3v
1999 12 2023-8-3
FRCornelis
Flight distance : 1252884 ft
Yes, I know we won’t get the 46 mins, but both Air 3 and Mavic 3/Classic are rated the same flight time.
Mine is in transit so I haven’t tested yet but I heard the Air 3 is getting much worse flight time then the regular Mavic 3 or Classic… can someone confirm?
2023-8-3
DowntownRDB
Flight distance : 1722 ft
I've had to return my Air 3 due a defective bottom LED light.  However, on the two flights I got in with fully charged batteries I averaged 36 minutes and landed with 12% battery remaining.  Probably could have eked out an additional 2-3 minutes but didn't want to press my luck on first few flights.
I love the signal strength of OC4 and having cruise control and waypoints is huge for me.  Can't wait to get the replacement Air 3 sent back to me.
2023-8-4
FRCornelis
DowntownRDB Posted at 8-4 05:18
Thank you for the feedback, that's good to know.
This is the first time I'm considering the AIR line, as previous versions they always had some sort of a weak flight time, so I thought the AIR 3 would fix that, and bring it to the the Mavic level in regards to actual flight time. So watching some post and reviews stating a lower flight time than Mavic 3 raised some red flags.
I know I'm going to be happy with the picture quality, so to me flight time, a robust signal in urban areas with some decent wind resistant is more important to me. I was going to get the Classic + Flight More Combo but with this new controller era situation with O4, I decided for the AIR 3... waypoints, night mode, and cruise control plus telephoto made it so hard to justify the price difference with Classic+FMC+RC Pro as long as flight actual time is no less than 30~34 mins.
-FC
2023-8-4
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. The new DJI Air 3 maximum hovering time is 42 minutes and the maximum flight time (flying forward) is 46 minutes. You may perform a test flight with your new unit in an open area away from any possible interference to check. Feel free to contact us if you have other inquiries or concerns. Thank you.
2023-8-5
DowntownRDB
FRCornelis Posted at 8-4 09:25
I'm certain you'll enjoy the Air 3 and the flight time it provides.  I really liked my Air 2S but the short flight time was always a negative factor.  Will pass the Air 2S down to one of the grandkids once I get the Air 3 back.
2023-8-5
JJB*
Flight distance : 12477300 ft
Hi,
Just checked 1 AIR3 log, general flying, video ON some part of the flight, taken pics,
Active track and sport mode in the log.
2.7 % batt usage per minute.
So 100 - 10% battery = approx 33 minute fly time.
cheers
JJB
cheers
JJB
2023-8-6
FRCornelis
JJB* Posted at 8-6 10:59
Hi,
That sounds great.
Is the drain linear?  like 2.7% when the battery is full ~ same 2.7% when the battery is below 40%?
2023-8-6
JJB*
FRCornelis Posted at 8-6 11:02
That sounds great.
Almost linear i would say. see my chart of a AIR3 batt from 95 > 17%
cheers
JJB    [ Charts by FRAP ; the 'best' software for data and visual flightlog analysis ]
2023-8-6
FRCornelis
JJB* Posted at 8-6 12:47
cheers
Great!
That's some data right there...
...while I'm still trying to calibrate the RC2 compass which I'm unable to follow the motion instructions shown on the guide, that's impossible to do LoL
So you would say.. you are NOT missing out (on battery/flight time) department comparing to the Mavic 3 (non Pro) ?
2023-8-6
JJB*
FRCornelis Posted at 8-6 12:57
Great!
Hi,
I do not have a Mavic3, so cannot answer your question.
cheers
JJB
2023-8-6
KLRSKIR
Flight distance : 28641640 ft
Great!
The Air3 and my Mavic 3 Cine are virtually identical regarding flight time. Below are the current flight times since I received it. Remember too that as the batteries acquire 5-10 full flight cycles they will improve in flight-time.
*Note - These flights have been cycled between four different batteries. The August 4th flight was on a brand new battery (first flight).
2023-8-7
angeloffate
Poland
like always 70% delared flight time
2023-8-7
KLRSKIR
angeloffate Posted at 8-7 05:51
The batteries are brand new. I'll post back after a few hundred mile flown.
2023-8-7
