Lightcut app max supported import resolution?
3128 36 2023-8-4
Suni
Flight distance : 508264 ft
Denmark
Hi Forum
What is the max supported resolution for imported clips in the lightcut app?
I am asking because I tried to import a 4k 30 fps clip and the app didn't allow it.
Hope you can help
Suni
2023-8-4
DJI Wanda
Hello, there. Sorry for the inconvenience. Currently, there are no requirements for resolution and frame rate, which depend on the support of your device.
However, there are requirements for the frame rate and format of the exported videos.
A: Android: MP4 format: 30 fps;
iOS: MOV format: 30 fps.
2023-8-4
jbrevan
Slovakia
Hello, i have problem with lightcut (android) 4k export, made 4k video with osmo action 3 and after oneone tap edit have only options to export in 720p or 1080p not in 4k any idea please how to export from lightcut in 4k?
thank you
2023-8-24
fans3b59eccf
Flight distance : 192618 ft
United Arab Emirates
DJI Wanda Posted at 8-4 06:18
I have the same problem with my iPad 12.9 inch. How to resolve it? Thank you.
2023-9-30
fans3b59eccf
I have the same problem with my iPad Pro 12.9 inch. How to resolve it? Thank you.
2023-9-30
stasvr67
jbrevan Posted at 8-24 05:31
thank you
I have the same problem with my iPad 12.9 inch but everything is okay with iPhone 13 Max Pro.
2023-9-30
DJI Wanda
stasvr67 Posted at 9-30 10:36
Hello, there. Sorry for the late response. As we have explained above, currently, there are no requirements for the resolution and frame rate of imported videos for the DJI Light Cut APP, which depends on the support of your device.
2023-10-2
stasvr67
DJI Wanda Posted at 10-2 04:41
Hi.
The question was about the export of the video after editing, not import to the app. I have imported video clips to LightCut with 4K resolution and a frame rate of 30 fps, but I can not export edited video from the application with a resolution higher than 1080P. How do we resolve this issue to export with 4K? Thank you.
My iPad is new, upgraded with the latest software and supports 4K video.
2023-10-3
DJI Wanda
stasvr67 Posted at 10-3 08:10
Hi.
What error message do you see when you choose the resolution of the exported video higher than 1080P?
Would you please record a video for us about that?
2023-10-4
stasvr
DJI Wanda Posted at 10-4 06:51
No error message, just I can not export video clip with higher resolution than 1080p despite imported video was in 4K. Unfortunately I can not upload video because your page doesn’t support such option, just still picture. Even still picture need to resize because it is not possible to upload picture bigger than 1Mb.
2023-10-4
stasvr
Video can not be uploaded.
2023-10-4
djiuser_x7Q0kDxQdoGd
Czechia
I have the same issue, do we have any update ?
2023-10-5
DJI Wanda
stasvr Posted at 10-4 07:37
[view_image]
[view_image]
Thank you for your reply.
Would you please feedback this issue to our LightCut team?
1. Tap “Settings” in the top right-hand corner and find “Contact us”.
2. Send an email to lightcutapp@gmail.com.
Please export the APP Logs of the Lightcut app for them to verify the issue further.
You can find the LOGS file in iTunes-LightCut
2023-10-7
stasvr67
DJI Wanda Posted at 10-7 02:03
I have already sent emails several times to the team at the provided address but no response from them.
2023-10-7
DJI Wanda
stasvr67 Posted at 10-7 09:43
Would you please tell us your email address in PM? I will let them check.
2023-10-8
stasvr67
DJI Wanda Posted at 10-8 04:11
stasvr67@gmail.com
2023-10-9
DJI Wanda
Thank you.
2023-10-10
fansdeeff0d8
Flight distance : 165174 ft
I have the same issue. I haven't been able to create and export 4k videos from the ipad version of the app. The iPhone and android version work fine. I have sent multiple emails no response and I left 2 negative reviews on the appstore which were taken down by apple. Seems apple only allows good reviews.
2023-10-18
fans2ca4ee32
Hi. No reply, no update and no solution for an issue till now. What is going wrong? Thank you.
2023-10-24
DJI Wanda
fans2ca4ee32 Posted at 10-24 10:35
Sorry for the late response. I checked with our teams. Currently, The iPad version of the DJI Lightcut App supports exporting the maximum resolution of 1080p videos.  If you need to export 4k videos, we recommend you use the iPhone version. We have forwarded the issue to our related teams. They will evaluate the request.
2023-10-25
fansdeeff0d8
Thank you for the reply. Though this is not good enough.  I bought the Ipad primarily to edit videos. The app used to export 4k videos from the ipad until recently. This it obviously a regression bug that could easily be fixed it you cared enough.
2023-10-25
fansdeeff0d8
I believe this has to dovwith the ipadOS17 upgrade. I pads with Os 16 have the 4k export ability with lightcut. Its the versions 17 and above that have this issue. Mine was working fine until I upgraded to OS 17
2023-10-25
fansb5fa54a6
Taiwan
Still 1080p in the latest version lightcut ipad 4.75.5
2023-11-7
Slowjam
Flight distance : 235679 ft
I’ve reported the same issue 2x and no fix for a month and a half now.  I was able to export in 4K until the late September 23 update.   Since that update I’m unable to export in 4K.  This app has potential but the dev team is not testing the iPad Pro which makes no sense!   Pls fix or revert it to the previous app.   It worked fine under the IOS 17 beta, so this issue is not IOS17 related!!!
2023-11-15
fansb5fa54a6
Taiwan
2023-11-20
fansdeeff0d8
Update today 23/11/23. Finally able to export 4k video on my ipad M1 pro 3rd gen and on  my ipad mini 6th gen. Still 2.7k on iPhone 7 p but 4k on every android device( Samsung s20 and tab s8) and iPhone 11. App is great and free
2023-11-23
Pedro_Laires
Portugal
I have the same problem with my IPhone 15 pro max. I can’t export video in 4k. I filmed in 4k but when I export I have only 1080 resolution, why?
2023-11-27
DJI Paladin
Flight distance : 318 ft
Pedro_Laires Posted at 11-27 16:44
Hi there. Thank you for reaching out. Could you please upload a screen recording showing the issue on your iPhone 15 Pro Max? You may upload the video via Google Drive or Youtube then send the link here. We appreciate your cooperation.
2023-11-28
fans2ca4ee32
fansdeeff0d8 Posted at 10-25 22:13
Yes, it is correct. My son has bit older model of iPad and 4K option is available there.
2023-11-29
fans2ca4ee32
Hi. I have checked app right now. Problem is solved and 4K is available.
Thank you.
2023-11-29
djiuser_JuAM8j1bX2jJ
Flight distance : 69 ft
Is anyone else having an issue with LightCut not importing video after the last firmware update
2023-12-24
djiuser_P7oldDu0f74U
Kazakhstan
please tell me if I can somehow save the video at 25 FPS? I have only seen 30 but my original video is 25
3-15 17:49
DJI Paladin
djiuser_P7oldDu0f74U Posted at 3-15 17:49
Hi there. Thank you for reaching out. When using the Lightcut app, we can only export video with a frame rate of 30FPS and a format of Mp4 (for Android) and MOV (for iOS). We will consider this as a suggestion and will forward it to the relevant team for attention. We appreciate your understanding.
3-16 01:46
Josh Rattray
I can’t even export any video regardless of resolution or frames, tells my I have no space to export and to retry, I have 58gb of free space. Anyone had this issue? I’m using iPhone 14 Pro Max
4-7 04:27
DJI Paladin
Josh Rattray Posted at 4-7 04:27
Hi there. We do apologize for the trouble that this has caused. Can you please upload a screen recording showing the issue via Google drive and then send the link here so we can investigate the issue further? we will wait for your response.
4-7 20:39
Josh Rattray
DJI Paladin Posted at 4-7 20:39
4-8 11:47
DJI Paladin
Hello, Josh. Please upload the file via Google Drive then send the link to us. Please keep us posted. Thank you.
4-12 02:00
