Transmitter beeping continually
1799 14 2015-8-30
loveshutter
Hi guys, when I turned on my P3 transmitter today, it wouldn't stop beeping, any ideas of what it might be?
Ron
2015-8-30
Sir Edward K
Maybe the home button was pushed that would cause it to beep.  beep beep...beep beep continually.
Or if you put it away but it is still on, and not connected to phantom, it will start beeping at you as well.
2015-8-30
terrylewis
Flight distance : 3517287 ft
What is the Left-most (status) LED doing? Which model - (Pro/Adv/Std)
2015-8-30
kieferli
hi I have a same problem I just updated the firmware tonight and all update was  success. After I press the battery button the transmitter was keep beeping a loud noise . and I try to test the control nothing working. But I could see the screen from the camera but can,t control anything at all. it is my first time have time problem
I changed to other battery and they still same. what should I do?
2015-8-30
kieferli
http://youtu.be/EJyUtgxpNpU
2015-8-30
DJI-Tim
That could mean that your sticks are not  centered
2015-8-30
kieferli
Ok I just try to update the firmware again and I let it beep and I wait for 8-10 mins the beep stop by itself . And now working again
Must be something wrong during the firmware transfer in my first time . Thank god lol
2015-8-30
loveshutter
Thanks guys, I have the pro version and the beeping started prior to the new update. It is the transmitter beeping, not the drone. It happens whether or not the drone is turned on.
The very left led is blinking red in sequence with the beeping. Battery is fully charged, Pilot App is newest version. Sticks appear to be centered.
2015-8-31
aparis99.gmail
It happens with me too. Just move the sticks. It's thinking they're not both centered. See if that helps.
2015-8-31
loveshutter
Thanks, aparis99, I tried that and it hasn't changed anything. :-/
2015-8-31
m.friedl
Flight distance : 3 ft
Austria
@loveshutter ,
Calibrate your RC and the Problem is solved
greetings Mike
2015-8-31
michaelangelo
Flight distance : 1821913 ft
As an earlier poster stated your RC control sticks are not centered. Probably from being out of position over a prolonged period of time. Calibrating the RC does resolve this issue.
2015-8-31
loveshutter
Thanks, guys, I'll try to calibrate and see what happens.
2015-9-2
loveshutter
I'm officially stumped. Calibrated TX and beeping continues.
2015-9-3
Mr Smith
Flight distance : 2993169 ft
I am having the same problem... constant beeping after I turn on the Transmitter, but it usually goes away if I move the sticks around a bit after I go into the camera view. anyone found a definitive solution to this yet?
2016-7-29
