SD card error
2462 6 2014-12-8
1djg53
Has any one had trouble with the camera on the P2 vision not reading the SD card? My camera is on a Propixel gimbal.
2014-12-8
Gerry1124
Did you turn off the Phantom before you turned off the video?
2014-12-8
1djg53
No, but I may have un-plugged the camera while P2V was still on, a no no by Propixel. I may have fried an internal board in the camera.
2014-12-8
Gerry1124
1djg53@comcast. Posted at 2014-12-9 01:03
No, but I may have un-plugged the camera while P2V was still on, a no no by Propixel. I may have fri ...
Try to make a short video and see if it will show.  Make sure you turn off the video before you turn off the Phantom battery.
2014-12-8
gil
Flight distance : 1379308 ft
Two things; First, what class card are you using (you can get a decent 16Gb class 10 card for around 10 bucks so no excuses!)  second, oxidation happens, I've found that I sometimes have to insert-remove-insert-remove-insert-remove just to make sure the contacts are making a good connection.
2014-12-8
Gerry1124
gil@wk.net Posted at 2014-12-9 01:26
Two things; First, what class card are you using (you can get a decent 16Gb class 10 card for around ...
Got 2 of them Gil, they work great, but still have the cheap 4 gigs in the box for backups only.
http://www.ebay.com/itm/25122934 ... =STRK%3AMEBIDX%3AIT
2014-12-8
1djg53
Thanks everyone for the reply's and suggestions.
2014-12-8
