Donnie - Apple 0
Flight distance : 3636782 ft
josh.sunvalleyphoto Posted at 2018-1-29 14:34
Yes - updated all firmware on all drones and remotes. I sent one of my drones back to DJI who said they repaired it (and I presume, made sure firmware was up to date so they could test it). I received it back from them - neither the drone nor the remote required firmware updates.
When I launched the drone, the signal was fine until my drone got about 300m away - still in direct line of site with no impairments - and the video feed started to fail. I had to return home and relaunch. This has happened at several different locations where I live (I live in a small remote town in central idaho). I am also getting a regularly error notice that reads "wireless interference, fly with caution". I get this error no matter where I fly - sometimes in the middle of no where with no power lines, homes or any signs of civilization. I'd like to note that my drones all worked perfectly fine until I updated the firmware and DJIGo app software that includes geofencing.
What are you using for the go ap device ? ( I pad Iar , MinI , samsung etc ?) it needs a fast processor now a days. In the past the older go app devices would work but with the latest encryption they needs tons of power .
Beg borrow or steal ( kidding ) another go app device like an I pad Pro or something with an A9 MINIMUM processor, this way you can at least narrow the problem down , if it goes away then you know that is the issue.
Here is a tips page with other ideas to try as well .
Video Transmission issues with X3 or X5 ? Try These Suggestions !
**** I get many of the same warning as well in the same flight areas whre I had none before. Just want to share that with you .
donnie
