Dji mini wind warning does not works properly
1621 7 2023-8-13
Andris01
Flight distance : 384747 ft
Hungary
Hi guys!
I recently discovered a very strange problem about wind warnings with my dji mini 2. In the last few weeks I went to several different places I got the same issues everywhere.
After I take off It always says "strong wind"even if there is actually no wind at all. It reduces the max altitude to 30 meter and the max distance to 50 meter. With this small range it is unenjoyable and difficult to take good shots. However, I noticed that it only does this when I fly low like the height of 5 or 6 meters. When I go up to 100 meters immediately after I took off and I fly high I do not got this message.
It used to work better. A year ago I was able to fly when there was wind, but now I couldn't even fly when there isn't any.
What can I do in this situation?
2023-8-13
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we do apologize for the trouble. Please go to a location without strong wind and have a test flight and then please take a screen recording showing the live camera view of the aircraft so we can check it further. You may upload the video using Google Drive or Youtube and send the link here. Furthermore, without propeller guards mounted, a red prompt will appear on the DJI Fly app when the wind velocity is more than 10 m/s for five seconds. The aircraft encounters strong wind and may not return to the home point. Please lower the altitude and manually return to the home point immediately. Please keep us posted. Thank you.
2023-8-13
MBSL500
Post deleted..
2023-8-13
mustangman
Flight distance : 541476 ft
I have started getting the wind warnings also.  I flew couple batteries through it and I got wind warnings both times.  No wind at all where I was flying. It is annoying because it turns payload mode on and restricts height.  Just started doing it after last update.
2023-8-13
Sean-bumble-bee
Flight distance : 15997 ft
Andris01, might it be a translation problem, either Chinese to Hungarian or Hungarian to English?
I ask because the combination of height and distance limits you see and report remind me of the  limitations imposed if you are not logged into the App.
Are you logged into the App?
As suggested my Mustangman, is the payload mode switched on?
2023-8-13
Andris01
Hungary
Hi guys,
Thank you for everyone who replied!
After reading mustangman's reply, I realised that I have the same problem. I used propeller guards too. That's why it automatically turned on payload mode and reduced the altitude and distance.
I took off the propeller guards and tried it in my garden. It worked like magic. I was able to fly high and far.
I am very glad that now it works like it has to. You all helped me a lot.
2023-8-14
mustangman
I don't have propeller guard installed and I never used to get the high wind warning.  Now I get it every flight and it automatically turns on the payload mode on by itself in the app.  It just started  doing this after last update.
2023-8-16
DJI Tony
mustangman Posted at 8-16 17:24
Hello there. Sorry for the inconvenience. Will you be able to post a video for us to check? We appreciate your patience.
2023-8-17
