Heijningen
Flight distance : 6055745 ft
You need to take the internal storage cards out of the camera (XQD and CompactFlash on the D4, CompactFlash and SD on the D800). This isn't technically necessary, but there are things you can do if a card is in the camera that'll reset the HDMI output to 720P that don't happen if no card is in the camera.
You set your frame size/rate via Movie Settings, as usual.
You need to turn HDMI/Advanced/Live view on-screen display to Off and HDMI/Advance/Output display size to 100%. These are not the defaults!
Depending upon what you're trying to do and what quality you desire, there may be more HDMI/movie settings you'll want to make. One to pay attention to is whether you want to output full or limited range. If you're new to video, you're going to get caught by this one eventually. Best choice: Limited range, as it puts black and white points within broadcast video safe limits.
If you're doing long takes, you must set CSM #C4 Live View to No Limit.
You generate the HDMI stream by using Video Live View (i.e. move the Live View lever to video, press the Live View button)
See for more info: http://www.bythom.com/hdmivideo.htm
