Add Screen record box
675 2 2023-8-18
RobCass
Loving my new Action 4, when you do the next firmware update for the Action 4, can you consider adding an optional red rectangle around the parameter of the screen while recording?
I know there are LEDs, but when cycling or Skiing, it would be much easier to see if the camera is recording if there were a bright red rectangle around the entire screen.
Obviously, add it as a user selectable option in case others do not want/need it.
User options should be:
1) Off
2) Both (front and rear screens)
3) Rear Screen only
4) Front Screen Only
Thanks
Rob
2023-8-18
osmonauta
Hungary
You know, you could just use a red magic marker to draw a frame around the screen before you press record, and when you finished recording just erase it :-)
2023-8-18
DJI Paladin
Flight distance : 318 ft
Thank you for your feedback. I will take this as a suggestion of yours and will forward it to our designated team for attention. After the evaluation of the engineers, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at www.dji.com. Thank you for your valued support!
2023-8-18
