Panorama's not stitching correctly.
2805 11 2023-8-19
Tom_765
Flight distance : 1139852 ft
I just took some photo's with my Air 3.  None of the Panorama's stitched correctly.  360 didn't.  Wide angle didn't.  I have the latest firmware and am using the RC 2 controller with the latest update.
Anyone else having this problem?
2023-8-19
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Please try the following solutions and check if the issue persists.
1. Please avoid shooting when the wind is strong. While taking a panoramic shot, keep the aircraft still. Please try shooting in an environment without wind and then check if the stitching is still abnormal.
2. Try shooting in an environment without wind after gimbal calibration and IMU calibration.
3. Please format the microSD card or use another mobile phone for shooting. Before formatting the microSD card, please back up the data.
4. Refresh the firmware using the DJI Assistant 2 software and try shooting again.
Please let us know if the issue still persists. Thank you for your understanding and support.
2023-8-19
fans20b63dac
One thing I find helps is doing a gimbal calibration, which should be under Control>Gimbal under the 3 dots menu at the top left on camera view
The auto calibration worked well for me
Hope this helps
2023-8-23
Geo_Drone
Flight distance : 2866296 ft
Romania
Yes, we have seen it too....in a very calm environment, without any wind, without water (terrain only), from 30 panorama, around 7 were stitched with HIGH errors....needed to stitch it in PTGUI, seems that the drone is moving fast for pictures and some of them appears blurred in areas. This makes stitching a lot harder.
Probably DJI need to add a refinement in making the picture when drone ended the movement.
2023-8-24
Tom_765
So, I did all the suggestions, and upgraded to the latest firmware, refreshed the update.  Formatted my SD Card. Used a different SD card.  IMU and gimbal calibrated. And still not getting the correct stitching.
2023-9-1
Tom_765
panovolo Posted at 8-25 04:08
Can't comment about quality of in-drone stitching, but suspect the algorithm is much simplified as "proper"  stitching is a very computationally intense task. If you use Windows you can try Panovolo, the beta version is now available for download.
I tried PanoVolo and have to say it is GREAT!
Thank yoU!
2023-9-3
djiuser_Mm7F6bX7DTXY
Flight distance : 4718179 ft
Albania
Hi, it's my second DJI Air 3 drone and both suffer the same issue. Photos in panorama mode are not aligned. I'm using the latest update and photos are saved in the drone internal memory.
2024-1-24
Wyldwestaz10
Flight distance : 1099068 ft
I noticed this on some 360 Spheres. I’m not going to waste all the time stitching them myself. The DJI software usually does a great job quickly so hopefully then can fix this soon as I believe it is a software processing issue. My MA2 has worked great for several years so I’m sure this can be remedied on the Air 3.
2024-1-24
Albania
Can anyone explain the pink/purple color on every shot and still with very average wind the panorama stitching is a disaster?
Air 3 no nd filters, auto mode.
2024-1-30
Labroides
Flight distance : 26781877 ft
djiuser_Mm7F6bX7DTXY Posted at 1-30 01:20
[view_image]
Large areas of water or blue sky can be difficult for any stitching software.
It cannot identify distinct points to match between adjacent images.
The in-drone stitching software is very basic and commonly shows problems with water horizons.
2024-2-3
GOREPOT
Flight distance : 13478 ft
same problem
2024-2-25
B0b2
I absolutely agree that the onboard stitching software is pretty basic and limited. The thing that is frustrating to me is that under very similar conditions and in the same location, panoramas that used to stitch together just fine using the onboard stitching algorithm are now not cleanly stitching. This can be resolved with a third party app, but it's an extra step that would be nice to avoid. I'm using Panorama Stitcher on my Mac and it has been working flawlessly and the price is right at around $15.
2024-8-24
