Tello camera colors
1928 3 2023-8-23
djiuser_riyhuDv749my
Belgium
**Solved**
Hello everyone. When I run my Tello Edu camera with my Python code, I realize that colors are not correct. My glass is yellow, but i see it blue.  Weirdly when it records it's camera again through the computer screen, as you can see its correctly yellow again. It works correctly on my tello mobile app too. I am confused can someone explain?
This is my code=
from djitellopy import Tello
import cv2
mydrone= Tello()
def main():
    try:
        mydrone.connect()
        print(mydrone.get_battery())
        print("connected")
        mydrone.streamon()
    finally:
        mydrone.streamoff()
Edit= I added         img=cv2.cvtColor(img, cv2.COLOR_BGR2RGB)   into my code and it was fixed, my apologies im a newbie
2023-8-23
Belgium
2023-8-23
Belgium
And this is in my phone:
2023-8-23
abdullah.osman
did you fix it? i am having the same problem
2023-11-19
