Air 3 battery question
2448 3 2023-8-25
virtual
Flight distance : 5161677 ft
Czechia
I like the new Battery Maintenence function (very likely cell balancing in "battery charging world", it definitely prolongs battery lifespan) but haven't seen (been reading Air 3 online guide) if the Air 3 battery pack has automatic self discharging like previous smart batteries?
It would be nice if there was option to recharge the battery directly to storage voltage only* in case I know I won't be flying a couple of weeks...
* Instead of recharge full then manually discharge to 60%.
2023-8-25
DJI Tony
Hi there. The Air 3 battery supports an auto-discharging function. You can check the image below:
You can also use this link to check: https://support.dji.com/help/con ... 52BkQ%25253D%25253D. Please reach back if you have further inquiries. Have a great day ahead.
2023-8-25
virtual
Czechia
Thank You, DJI Tony. That's the information I was looking for! So the controlled self-discharge is tiny bit adjusted from Air 2 line of drones - 96% when idle for 3 days (Air 2 and Air 2S 1 day) and discharge to 60% after 9 days left idle (same as Air 2S) while Air 2 only 5 days...
Great day to You as well!
2023-8-25
DJI Tony
virtual Posted at 8-25 03:36
You are most welcome, virtual. I am happy to assist.
2023-8-25
