DJI FPV problem gimbal calibration stuck at 60%
1726 7 2023-8-25
Rex02468
Flight distance : 572992 ft
Switzerland
Hi, I have some problem with the calibration of the gimbal.
I start by saying that the drone has never fallen.
Today I wanted to fly and the message appeared that I need to calibrate the gimbal, so I go to the settings and start the calibration but it remains at 60% and the gimbal remains facing down.
If I try to fly it but everything works, the gimbal remains stabilized and everything else works.
Everything works except when I put it in manual mode the drone doesn't do stunts but stops at a certain inclination and the message that the gimbal needs to be calibrated keeps coming out.
Help?
2023-8-25
DJI Thor
Flight distance : 13602 ft
Hi Rex02468, thank you for reaching out. For your concern, you could please refer to the following steps and check first, thanks.
1. Please check if the gimbal is stuck by a foreign object. If yes, please remove it.
2. Please restart the drone, and then let the drone on a level surface to calibrate again. Do not touch the gimbal during calibration.
3. Please refresh the firmware version, and make sure the firmware version is the latest.
If the calibration still fails after trying, it is highly recommended to send back for comprehensive check to ensure the long-term usage. You could register through the following link, https://repair.dji.com/, to create a case and send back the device for diagnosis. If you need assistance while submitting, you could also contact with our support service, http://www.dji.com/support. Thanks.
2023-8-25
Rex02468
Switzerland
DJI Thor Posted at 8-25 20:11
The gimbal works, if I move the wheel on the remote the gimbal goes up or down, so there is nothing stuck.
I've already restarted the drone several times, and I've already connected it to my computer to reset it and re-download the new firmware.
But the calibration still doesn't work
2023-8-25
DJI Thor
Rex02468 Posted at 8-25 22:19
I see. If the calibration still could not complete successfully, please send back to us for further diagnosis. Thanks.
2023-8-25
djiuser_ndfdUxgdrzUV
Sweden
Hello
I have the exact same problem.
But my avata have been bought and unused for over a year…
Now when I start flying the camera fails as in this description.
What can I do?
2-27 11:50
DJI Gamora
djiuser_ndfdUxgdrzUV Posted at 2-27 11:50
Hello
Hi, djiuser_ndfdUxgdrzUV. We're sorry to read about this. Please try the steps from this post.
2-28 00:27
djiuser_CoEh9po7eeEE
Flight distance : 134436 ft
I have Exactly same problem!(Issue/situation) Stuck on 60% calibrating gimbal. I have turned off and on. Replaced battery's. I even tried to touch the gimbal a little and nothing.. then when drone is moved, calibration is ended..
5-2 06:34
DJI Susan
djiuser_CoEh9po7eeEE Posted at 5-2 06:34
Hi there, we are sorry for any inconvenience, you could please refer to the following steps and check first, thanks.
If the calibration still fails after trying, it is highly recommended to send it back for a comprehensive check to ensure long-term usage. You could register through the following link, https://repair.dji.com/, to create a case and send back the device for diagnosis. If you need assistance while submitting, you could also contact with our support service, http://www.dji.com/support. Thanks.
5-2 19:13
