DJI O3 air unit do not bind blinking Green light no red led
2593 4 2023-8-25
FPVTHAI
Thailand
i have an issue with a newly open air unit O3 where the it will not go in to binding condition the green led blinking continueously  all the firmware is up to date the flashing went 100% ok . i can do not know what is the problem please help.
My first impression was a firmware issue but i already updated all the firmware. Im guessing its a hardware issuehere is what is happeeing in my video
https://youtu.be/bopPXkgZCEU?si=-QlSrfvDkHF1yOly
2023-8-25
DJI Gamora
Hi, FPVTHAI. Thank you for reaching out. If the green light of the DJI O3 Air Unit flashes, it may be that the power supply is insufficient. Please check whether the power supply is sufficient. If the battery is sufficient, please send the DJI O3 Air Unit back for inspection.
2023-8-27
FPVTHAI
Thailand
DJI Gamora Posted at 8-27 07:50
Im 100% sure the power is sufficient ,the batter is a 4s 1500mah fully charged
please advise on a solution
2023-8-27
FPVTHAI
Thailand
can you please advise on how and where i should send the o3 back ?
Im currently in Thailand , is there a service center in the region?
2023-8-27
DJI Gamora
FPVTHAI Posted at 8-27 21:33
Hi, FPVTHAI. Please contact our DJI support at (https://www.dji.com/support) as they will provide you with the nearest service center in your area. Thank you.
2023-8-30
