Sean-bumble-bee
Flight distance : 15997 ft
If the drone is still bound to your account you can still undo the binding, in fact YOU SHOULD UNDO ANY BINDING, otherwise the 'next buyer' is going to run into problems.
All you need to do is connect the/an app to the internet and undo the binding there. If necessary this can be done using a App, freshly installed on a phone etc.. That app just needs to be logged into you DJI account and connected to the internet to do this.
What controller was returned with the drone?
There are logs stored on the drone but they have a limited life span due to limited storage space, meaning the oldest logs are over written as needed.
If you returned a smart controller then, unless you wiped or perhaps reset the controller, there are logs on there but they individually time and date stamped. As such those logs would show usage separated by time etc. and if you have paperwork showing that you returned the drone then it would be obvious that the drone was no longer under your control.
The logs stored on a smart controller can be read via computer by anyone. The logs stored on the drone can also be accessed via computer but DJI would need to decrypt them. If you returned a smart controller and think the app was still logged into your account then I would suggest that, on a phone etc., you log into the your DJI account via the app and then log out of the app. In experiments I have done logging out of the app on one device will cause the app on other devices to be logged out when those other devices are next connected to the internet,
If the controller WAS NOT a smart controller then, as far as I know, no logs stored on a 'dumb' controller.
