Can't connect my phone to RC
18712 30 2023-8-28
djiuser_H6RP6p66LUXn
Flight distance : 884708 ft
Greece
Hello, i have a new dji mini 3 and i have huge problem trying to connect the RC to my phone (Xiaomi Redmi 11s), there is constantly connected/disconnected every 1 sec so i cannot fly at all. I need to note
1) there is NO Problem with the cable, the same cable with other phone work perfect with the RC.
2) When i connect my phone to my laptop it works normally
So i dont know where is the problem i have try everything i could think, any advice?
I have post a video to YouTube so y can see more clearly the disconnection problem here it is:
2023-8-28
DJI Tony
Hello there. Sorry about the inconvenience. Can you please try the steps below and see if it will help:
1.     Restart the remote controller. Please restart/reinstall the App (Ensure the latest App version is used). Unplug and reinsert the cable.
2.     If your mobile device uses an Android operating system, please turn on the USB debugging and select the charging-only mode.
3.     Check whether the copper sheets in the Type-C port of the remote controller are warped. If so, please send back the product for repair. (The copper sheets are easily damaged for inclined unplugging and insertion. Please plug and unplug the cable vertically.)
  Normal Type-C port (The upper and lower rows’ copper sheets are attached to the center part inside the port, which is not warped.)
  Malfunctioning Type-C port (The two copper sheets of the lower row inside the remote controller port are warped.)
If the above troubleshooting solutions are all detected to be normal, continue with the following step:
4.     Verify the reversibility of the Type-c port insertion and check whether the wire is abnormal:
As for Type-C to Type-C adapter cable of the remote controller:
Try to plug one end of the cable with the remote icon into the mobile phone, and another side to the remote controller. Plug the port in the same direction as the storage (can be stored), and plug upside down for further try (cannot be stored).
5. If no option for connection is prompted after an Android mobile phone is connected to the remote controller, it is recommended to connect the mobile phone to a computer to test if the connection will be successful. If not, it is recommended to contact the mobile phone’s manufacturer for tests and maintenance. Before connecting the mobile phone to the remote controller again, make sure that it can be connected to a computer.
I understand some notes have already been tried but I still included it for the others. Please keep me posted. Have a great day ahead.
2023-8-28
Whitestone Wings
Flight distance : 1311463 ft
I had the same problem with my Blade X1 using the controller for a mini-SE.  My solution was to buy a cheap Samsung on Ebay that is compatible with the DJI Fly app, The plus side is I no longer have to worry one way or another about phone calls when flying. .
2023-8-28
Greece
DJI Tony Posted at 8-28 21:22
Hi Tony, thanks for yr answer, i have chech all the list you sent one by one and nothing works, my phone connected perfectly with any laptop, but not with the dji RC. Any other phone i test connect normal with the RC. Any idea what other could be the problem?
2023-8-29
DJI Tony
djiuser_H6RP6p66LUXn Posted at 8-29 08:04
Hello there. This is usually due to a MIUI 12 system issue. If not yet, please update the MIUI13 system to the latest version and have another try. Please keep us posted. Thank you for your patience.
2023-8-30
Greece
DJI Tony Posted at 8-30 03:14
I have the MIUI 14 version (14.0.4)
2023-8-30
DJI Tony
djiuser_H6RP6p66LUXn Posted at 8-30 03:24
I see. Seems like we have already checked on everything. I don't think there is a problem with the remote since as you mentioned you tried other phones and cables and it's working perfectly. And it looks like your Redmi 11s is fine and not showing any disconnection from your computer. I'm afraid this is a compatibility issue. I am sorry but I suggest using a different phone, preferably a phone that is on the "Recommended list" (see Mini 3 Downloads)as those are devices optimized and guaranteed to work accordingly. Thank you for your patience and understanding.
2023-8-30
Don Vino
Philippines
I have same problem with my Redmi Note 10, it works on my Poco X3 NFC but when I tried it on my Redmi Note 10 it says  RC Not connected to the mobile device
2024-1-15
DJI Gamora
Don Vino Posted at 1-15 18:41
Hi, there. Thank you for reaching out. Generally, devices not listed as supported mobile devices can also be used if their system versions are the same or later than those published on the DJI official website (Beta system versions may not be compatible), but their stabilization has not yet been verified. If you experience any problems with the device that is not listed, this may be due to compatibility matter. Thank you for your understanding.
2024-1-20
Dan DJI Drone
exact same problem here, my iPhone 14 will not recognize or connect with my Mavic Classic 3. The drone, the controller, and my iPhone are all three turned on and connected to one another, the drone and controller are connected, and the controller and my iPhone are connected via USB cable to their data ports on the bottoms of both of them. WHY the STINK are they NOT seeing each other??? SO frustrating when tech doesn't WORK! Especially expensive tech! how the stink am I spotted to update my drone's firmware then??? what am I not doing correctly???
2024-2-16
DJI Paladin
Flight distance : 318 ft
Dan DJI Drone Posted at 2-16 14:19
Hi there. Thank you for reaching out and we do apologize for the trouble. Kindly please reinstall the DJI Fly app on your mobile device then try to connect again to your remote controller and check if the issue persists. If yes, you may try to use a different USB-C communication cable and make sure to plug it in correctly to further isolate the issue. If you have a different mobile device on your end, you may also try to connect so we can check if the behavior is still the same. Please keep us posted so we can help you further. We appreciate your cooperation.
2024-2-16
Cameron Cranley
Colombia
I have the same issue with my Samsung s23 ultra.
2024-3-3
DJI Paladin
Cameron Cranley Posted at 3-3 05:05
Hi there. Thank you for reaching out and we do apologize for the trouble. Can you please confirm what specific DJI product are you using? Have you tried to perform the troubleshooting steps above to possibly rectify the issue? If you can upload a short video showing the issue that would be very helpful. Please keep us posted.
2024-3-3
fans022d711a
Did you ever get anything working? I also have an s23 ultra and cannot for the life of me get it to connect to dji fly app
2024-3-31
DJI Paladin
fans022d711a Posted at 3-31 03:49
Hi there. We do apologize for the trouble that this has caused. Have you tried to download the latest version of the application on our website to further isolate the issue? If the issue persists, please upload a short video showing the issue via Google Drive then send the link here so we can check. Please keep us posted.
2024-3-31
djiuser_pm7qEeOtz2ws
I am now having the same issue with my Mavic 3 Pro and I use iPhone 15 Pro Max. I have deleted and reinstalled the app. Used a different cable. Connected on my laptop and all seems to work. What else can I do apart from buy a new controller? It was fine the previous day then suddenly it stopped worked for no reason at all
2024-4-21
djiuser_mqCBWSDMqxLj
It looks like this is an endemic problem, so I am not hopeful for a satisfactory solution.   I cannot connect my brand new DJI mini 3 to the remote controller.... apparently just like everybody else.
first, my usual phone is a Pixel 7... and that phone isn't even supported by the app.  (one of the most common phones in the world, and the MOST standard android phone... really???)
so as a backup... I installed the app on an Apple 12.   on that phone I get two steps into the installation process before it stalls.   I power up the Remote control and the drone, and plug the cord into the phone (and the phone makes the "tone" to let you know something new has been plugged in) but the installation process just stops there, and it never connects to the drone.
this is really frustrating.   honestly, it seems from reading the recent app reviews (almost all of which are 1-star, and complaining about the same issue) and this forum that DJI's app simply doesn't work.   It is a shame, but I guess I will be returning the drone.
2024-4-21
DJI Tony
djiuser_pm7qEeOtz2ws Posted at 4-21 14:28
2.     Check whether the copper sheets in the Type-C port of the remote controller are warped. If so, please send back the product for repair. (The copper sheets are easily damaged for inclined unplugging and insertion. Please plug and unplug the cable vertically.)
3.     Verify the reversibility of the Type-c port insertion and check whether the wire is abnormal:
Try to plug one end of the cable with the remote icon into the mobile phone, and another side to the remote controller. Plug the port in the same direction as the storage (can be stored), and plug upside down for further try (cannot be stored). 4.  Try other devices or connect the remote controller to a computer.
Please let us know if the issue persists. Thank you.
2024-4-21
DJI Tony
djiuser_mqCBWSDMqxLj Posted at 4-21 18:52
Hi there. Sorry about the trouble. Please try the procedures above in reply 18#. Please keep us posted. Thank you.
2024-4-21
DJI Tony Posted at 4-21 21:36
Post #18 is just another user pointing out that the app doesn't work.
2024-4-22
DJI Tony
djiuser_mqCBWSDMqxLj Posted at 4-22 08:20
Hi. My apologies for the confusion. Please try the procedures at 24#. Thank you for your patience.
2024-4-23
DJI Tony Posted at 4-23 02:54
there does not appear to be a problem with the cord connectivity
2024-4-28
DJI Tony
djiuser_mqCBWSDMqxLj Posted at 4-28 07:58
I see. In that case, I suggest sending the remote back to DJI for further diagnosis. You may submit a repair request here (https://www.dji.com/global/support). The warranty can be applied depending on the assessment's outcome, including your unit's warranty period. Have a nice day.
2024-4-30
djiuser_09PSoCuO9TXr
Whitestone Wings Posted at 2023-8-28 21:45
Same issue with DJI Mini 2 SE on my Samsung s22.
Tried usb debugging and reinstalling DJI fly app
I have an older Samsung A40 laying around. Perfect for the drone and save my actually phone from usage.
But really sad it doesnt work on a lot of phones...
2024-5-30
djiuser_j4EY09OhnNxH
Hi
I use Samsung galaxy s23 ultra and can't conect to controller
When i reinstal the dji app working ones and when i try again my phone starting to charge but no conection with the controller
2024-6-17
DJI Natalia
djiuser_j4EY09OhnNxH Posted at 6-17 08:07
Hi
Hi there, thank you for reaching out. May I confirm the remote controller you're trying to connect with your mobile device first for us to advise accordingly?
Looking forward to your response. Thank you for your support!
2024-6-18
djiuser_UdoOPguKGQSk
Having same issue. S23 ultra and mini 4k drone. The phone connects as we see it charging. Then it seems to say check connection every couple of minutes.  The RC is not confirming the connection. Spending a lot of time troubleshooting. For the price of this kit. Really dismayed.
2024-8-28
DJI Diana
Flight distance : 2408 ft
djiuser_UdoOPguKGQSk Posted at 8-28 07:58
Hi there,
We apologize for the inconvenience. Please reinstall the DJI Fly app on your mobile device, then attempt to reconnect to your remote controller and verify if the problem continues.
2024-8-31
Steve Myers
I have the same phone and problem. Did you get yours working and how. Works perfectly with wife's S23Ultra
2024-9-26
djiuser_uCmskUsfF0Ei
Slovakia
Hi, i have poco x6 pro 5g, eu version, android 14, usb debugging is enabled, otg too, old app dji fly instaled, then new app installed, some others apps instaled, but it won't connect the phone with rc of my mavic mini.. when I plug the phone with rc via the usb c original cable, it's not ask me if I wan't charging, or transfer files, but automatically start's charging the battery. On my old phone it ask me what I wan't do.. But here not. With old honor it was working perfectly..
2024-10-28
djiuser_y8V07EqpnJLd
Dji fly does not connect to iPhone 14 Pro. Was working fine for past 2 years until this morning. Today it doesn’t recognize that cable is connected.  I’ve tried on both a mini2 and a mini3 with different controllers, different cables etc. I’ve removed and reinstalled fly app.
App opens but does not connect. When I try to use the connection guide it takes me to first step but never beyond as it never recognizes when I connect the cable.  Suggestions???
2-1 06:46
