RSC2 Pan axis behaviour not normal?
544 2 2023-8-29
sfstudio
Hello there,
after a long time I want to use my RSC2 again and have some issues regarding the pan axis.
RSC2 users - can you please watch my two recorded videos and comment this?
If I tip the RSC2 to the left or to the right there is a point where the pan axis moves round about 15 degrees very quickley.
It results in a shake of the image (see screen of the camera). I think it´s not normal.
Balacing of the gimbal is excellent (balance test).
Did a motor test, balancing test, factory reset. But nothing helps. (Or is it normal).
Here the two videos. Nr. 1 in the Pan Follow Mode, Nr. 2 in the Pan Tilt Follow Mode.
https://www.dropbox.com/scl/fi/rq8dfgqm35723ytkknule/IMG_3533.MOV?rlkey=dqfmdxvrahjww5jh33sr0l6ee&dl=0
https://www.dropbox.com/scl/fi/d6h4pypzlgevimi5rp7l3/IMG_3534.MOV?rlkey=qoqawsk2bdjt45j812y2vny14&dl=0
Thx for your help :-)
2023-8-29
DJI Gamora
Hi, sfstudio. Thank you for reaching out. Let me forward this to our relevant team for further checking. We'll let you know once we receive an update. Thank you.
2023-8-29
sfstudio
Something new here? Need a response what I can do to fix this behaviour.
2023-9-5
