Binding
1369 8 2023-8-30
djiuser_SaoDAUShZ1dz
Flight distance : 125538 ft
Hi
I have dji mini 3 pro i am flying with both controller and integra goggles,
Do i have to bind either controller everytime i fly ot if i fly with goggles next time if i fly with goggles again do i have to rebind. Or is it only when i go back to the standard controller. I  doont want to fly without being covered by the dji refresh.
2023-8-30
DJI Diana
Flight distance : 2408 ft
Hello. Thank you for bringing this up. If the aircraft is bound to a standard remote controller, the goggles will prompt the user to change the bound device. Please connect the goggles to the mobile phone and change the bound device, bind a new device, or unbind the bound device in DJI Fly. To unbind the remote controller and bind the DJI Goggles, follow the steps below. Thank you.
1. Go to the DJI Fly homepage and tap "Profile".
2. Tap "Device Management".
3. Select the connected aircraft.
4. Tap "Value-added Service" -> "Unbind Device" to unbind the aircraft and remote controller.
5. To bind the aircraft to the DJI Goggles, go to "Device Management" -> "Value-added Service" and tap "Bind New Device".
6. Confirm the account number and the serial numbers of the aircraft and DJI Goggles, then tap "OK".
7. When a prompt stating "Binding successful" is displayed, this indicates that the aircraft is successfully bound to the DJI Goggles.
2023-8-30
Ralph_D
Flight distance : 285653 ft
DJI Diana Posted at 8-30 15:39
Is this ever going to change? When I bind with the controller I don't have to use my phone??
2023-8-31
DJI Diana
Ralph_D Posted at 8-31 08:13
Hi there. Thank you for reaching out. Apologies, the steps provided above are needed, and using your phone is an essential part of the process. Hoping for your kind understanding.
2023-8-31
jeffgauthier
Flight distance : 1578967 ft
DJI Diana Posted at 2023-8-30 15:39
is this the same for the AIR 3. after connecting the air3 to my invictor goggles and motion controller, I get the message that the device is not bound and I can fly 4 more times.   How do I fix that?? Thank you in advance.
2-11 14:57
jeffgauthier
jeffgauthier Posted at 2-11 14:57
And, can i Do this on the RC2. without a phone?
2-11 14:59
DJI Thor
Flight distance : 13602 ft
jeffgauthier Posted at 2-11 14:59
Hi there, thank you for reaching out. You could following the steps above DJI Diana provided on your DJI RC 2 without the phone. Thanks.
2-11 23:25
jeffgauthier
DJI Thor Posted at 2-11 23:25
OK, unbinding works on the RC2. However, when I turn on the goggles AIR 3 and motion controller, I do not get a message to bind the AIR 3 to the goggles. Seems to automatically bind after unbinding from the RC2.
If I stay bound to the RC2 the goggles won't connect cause it's "bound to another device".
I just want to make sure that I am covered for fly away when I use my goggles, and am not getting any warnings.
2-13 13:47
DJI Thor
jeffgauthier Posted at 2-13 13:47
Hello jeffgauthier, I would like to know if the Invictor goggles are made by a third-party brand.
For instance, our DJI Goggles Integra can only be used with DJI RC Motion 2, not DJI RC 2.
If you used goggles from a third-party brand, it is recommended that you contact them to verify compatibility. Thank you.
2-13 23:50
