Dji o3 broken antenna
1279 2 2023-8-31
David Kristek
Czechia
Hello,one of my cabels from dji o3 air unit antenna  broke off from the ufc connector (photo) and if I put it back it doesn't seem it's connected. Even without the cabel the dji goggles connect without a problem. The main thing  I want to ask about:  Will it cause any problems with range? And also Do you have any idea how to fix it without the need of buying whole new dji o3 antenna?
Thanks so much
2023-8-31
SeehawerB
Flight distance : 5414203 ft
Could you provide a better photo where one can see if the cable has been ripped off the connector?
But in general: HF transmitters shall not be operated without the correct output impedance. They could be harmed doing that. So if the cable is ripped off or has a short in both ways do not use the O3 anymore until you replaced the antenna. It only costs some bucks (19 Euros in EU) and is easy replaced.
2023-8-31
robomaniac
you need special pliers to strip and crimp ufl connectors or follow this video . Those antennas are 15$. https://pyrodrone.com/products/f ... sid=cdedc5342&_ss=r
2023-9-2
