Zenmuse L1 Terra Issues
1520 2 2023-9-1
JMikeyH95
Hi,
I'm having issues processing L1 data in Terra which I have not experienced before. Nothing untoward or unexpected occured during the two flights, each at a different location many miles apart. Automatic mission flight was in use for the L1 data capture and RTK connection was active. Occasionally the RTK connection would drop momentarily due to sporadic mobile data signal in the areas but it was not a huge problem. When the connection dropped, the flight was automatically paused and was not resumed until a strong RTK connection was reestablished.
Upon returning to the office after flying the first site, the gathered set of data (3 individual raw data folders processed together) was stuck processing at 13.9% overnight. Seeing it was not progressing, I cancelled it and began processing them one by one. After setting the first one going I went out to fly the other site. When I returned I saw it had stayed at 0% reconstruction. I cancelled this and instead began to reconstruct the second site whilst troubleshooting the first site.
The second site's data reconstructed, but as you can see in the image below it clearly did not reconstruct correctly.
Huge gaps of data are present in the middle of the site which were flown.
This job had 4 individual raw data folders, so as with the last job I instead began to run them through one by one, instead of all 4 at a time, and see if I got any progress with that. When attempting to run them through one at a time, each one failed. It presented me with an 8006 error, which is an RTK issue according to Terra however there was no data recorded without a strong RTK fix, all files are present within the raw data and nothing has been renamed so Terra should be able to see them.
Does anyone have experience with this issue?
Thanks,
Jon
2023-9-1
JMikeyH95
One of the raw data folders
2023-9-1
LV_Forestry
Flight distance : 4726654 ft
Latvia
https://forum.dji.com/forum.php?mod=viewthread&tid=285647&mobile=2
2023-9-1
