iFlight F5X v2 (DJI o3) Video drops for 0.5 seconds every ~1/2mins
535 1 2023-9-1
UnnamedUser
Hi All,
New here, apologies if this is in the wrong place but I'm having some issues with my DJI setup and hoping someone can help/make a suggestion.
I've searched the internet for the issue that I have and nobody is discussing it, not sure how I'm the only one, but here goes...
I've had my iFlight F5X for 2 months, bought new from China via AliExpress, been flying it for the last 2 weeks with an issue, it seems that after a short while of flight the video cuts out for a split second and then comes back, I have to enable angle mode, maintain some throttle and hope that I don't crash
Tried to fix it so far by...
I've pulled the o3 apart and made sure there's enough thermal paste
Visually checked the camera to o3 cable
Reflashed the firmware on my o3 air unit and DJI v2 goggles
Tested flying without an SD card (no recording) and I don't record on my goggles
Swapped the antennas on the drone and on the goggles
My setup is a standard iFlight F5X, without GPS, running 6S, o3 on FCC, ELRS receiver
Fingers crossed for suggestions
Ben
2023-9-1
UnnamedUser
Just in case someone else has the same issue, the fix is below:
Remove goggle SD card
Format on PC (removing any FCC files/hack files)
Format in goggles
Reboot goggles
Copy any FCC/hack files back to SD card (via PC)
Reboot goggles
You may be able to just format the SD card via the goggles, but this is the method I followed and it worked for me
2023-9-6
