WPML finish action without using the preset go home height
242 0 2023-9-5
djiuser_SInUVLhYPplT
Hi Developer,
Hope you have a good day. I got a problem on exporting my mission to kmz. Actualy, the mission work fine but the only home problem is when set the finish action to "GoHome".
I suppose it will go up to the expexted go home height and then go back to the home location, instead it directly go back to home with current altitdue. Is it anything i need to set in the kmz file?
Remarks: I already checked, it had been successfully change the gohomeheight to expected height also double check with dji pilot2 the value was setted correctly
Regards,
Godfrey
2023-9-5
