No gyro data in o3 clips! settings are correct!
930 1 2023-9-20
fans2553d362
Flight distance : 295 ft
Romania
Hi guys... maybe you've encountered this before... on just one of my drones i do not get any gyro data from my camera... all of them are with o3.. all have the same setings.. same firmware.. i did everything by the book... i'm thinking that maybe it is a hardware issue ? can it be the camera cable ? i've change it with a longer one to fit my frame... it is an original cable from DJI... did the same for a friend of mine.. same frame same cable.. he has data.. i don't.... i'm starting to lose patience with this particular o3... does anybody else encountered this ?
Thank you.
2023-9-20
djiuser_u92v2QMY0SqC
Norway
(Here’s my Issue & Solution):
• I installed a longer “170mm RunCam” camera cable to fit my 7” frame and got this Gyro Error Message.
• Solution: Re-installed the original “DJI” camera cable and get Gyro Data now.
Of course this isn’t a real solution because I still need a longer camera cable, but at least I found the cause of the problem.
Just wanted to share in case you still have the issue. I tried re-installing it but got the same issue again… not sure if it’s my specific cable or the RunCam cable in general that cause the issue.
4-13 09:27
