Will kmz created with google earth pro be downloaded and recogniz...
874 1 2023-9-21
homura
Japan
I downloaded goole earth pro.
I tried that I can import .kml and export .kmz.
I am an engineer and currently developing dji cloud api.
I have checked the demo source code for the dji cloud api.
However, I don't have the drone and RC at hand, so I can't check it properly.
So, I have a question.
I think that when I get the wayline list (.kmz) from the cloud api, and then push the button, the download will start.
When I do that, does it recognize the .kmz file as the one created by google earth pro?
・wayline sequence
https://developer.dji.com/doc/cloud-api-tutorial/en/feature-set/pilot-feature-set/pilot-wayline-management.html
・wpml
https://developer.dji.com/doc/cloud-api-tutorial/en/api-reference/dji-wpml/overview.html
・RC Native(in pilit2 application layer)get wayline list vi cloud api server
https://developer.dji.com/doc/cloud-api-tutorial/en/quick-start/function-display-video.html#pilot-wayline-management
2023-9-21
kahixa
It's important to ensure that the data format in the .kmz file adheres to the KML standard, with the necessary elements and coordinates properly defined. This will help ensure compatibility with Google Earth Pro and other KML-compatible software.
If you encounter any issues or need further assistance, you may want to reach out to DJI's developer support for guidance on generating KML/KMZ files that work seamlessly with their Cloud API and Google Earth Pro.
2023-10-16
