Battery Communication Error
3665 5 2023-9-24
Greg1000
Flight distance : 203461 ft
Hello DJI forum, any suggestions for this problem?
My Mini 3 Pro reports a Battery Communication Error on the RC Controller and does not show the battery level or battery SN.
Observations:
- Mini 3 Pro shows left LED light blinking after drone is turned on
- All 3 batteries behave the same, but one battery shows two LED lights in charger and does not charge. Other 2 batters charge normally but produce the same error.
- Have checked firmware on each battery and fly app reports all are current
- Have tried refreshing firmwar with DJI Assistant 2 and each drone/battery combination fails at 87%
- Have used factory supplied cable
- Drone was working normally last week, no hard landings or crashes experienced with this drone.
Thanks for any tips to try to resolve this.
2023-9-24
DJI Gamora
Hi, Greg1000. Thank you for reaching out and we're sorry for the inconvenience. Since the issue persists after trying several batteries, kindly send the batteries and aircraft back for inspection as the aircraft or the batteries may be malfunctioning. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support).
2023-9-24
djiuser_RIDalFChluqm
Mexico
HI THERE! I HAD THE SAME PROBLEM, SO, DID YOU SOLVE THIS?
2024-2-19
Greg1000
djiuser_RIDalFChluqm Posted at 2-19 16:11
Hello, thanks for asking. YES! DJI's return / diagnose / fix / ship process was very well communicated and generous because my Mini3Pro had no coverage. Their online tracking tool monitoring the progress of the return made it really easy. Very satisfied.
Greg
2024-2-19
DJI Tony
Hi there. Sorry about the trouble. If you are encountering the said error above, please try the procedures below:
1. Try another battery (if any).
2. If the issue is resolved after using another battery, it indicates that the battery is malfunctioning.
3. If the issue persists after multiple battery replacement attempts, it is recommended to wipe the metal contact pins on the battery or the aircraft body with isopropyl alcohol (with a concentration greater than 75%).
4. Refresh the firmware via DJI Assistant 2 on the computer, insert the battery into the aircraft body, connect it to a computer, and refresh the firmware. You can download the Assistant 2 to your computer here: https://www.dji.com/downloads/so ... sumer-drones-series
Please keep us posted. Have a great day.
2024-2-20
Civitas
Flight distance : 6703 ft
I had the same problem with lights 2 and 3 lite and the battery unable to communicate with the controller. I was able to turn the drone on with the bad battery and found it needed a firmware update. Now the battery works as normal.
2024-12-10
