Mini 4 Pro batterys
3726 29 2023-9-25
Potato mini
Flight distance : 7275348 ft
Does the M4P has the same Batterys as the M3P?
2023-9-25
Space Dream
The Mini 4 Pro battery is about 3 grams lighter than the Mini 3 Pro battery !
If a Mini 3 Pro battery is inserted into the M4P, the 250g will be exceeded
If M4P battery is inserted into the M3P drone it becomes slightly lighter
2023-9-25
Potato mini
Space Dream Posted at 9-25 09:59
but the batterys will fit?
2023-9-25
Space Dream
Potato mini Posted at 9-25 10:01
Yes, that is what many reviews say
2023-9-25
Suren
Flight distance : 13498560 ft
New Zealand
They look almost identical
2023-9-25
Suren
New Zealand
2023-9-25
Suren
New Zealand
https://www.dji.com/nz/products/ ... uct-page-comparison
2023-9-25
Mobilehomer
Flight distance : 18150351 ft
Here, straight from DJI!
2023-9-25
Potato mini
Thanks for the info. this will be great for the M3P pilots who want to up grade although I'll probably just wait till the next drone comes out in 11 months
2023-9-25
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. The DJI Mini 3 series battery is compatible with each other (Mini 3, Mini 3 Pro, Mini 4 Pro) However, the DJI Mini 4 Pro battery will only work with the DJI Mini 3 Pro and DJI Mini 4 Pro. Please don't hesitate to reach us if you have other inquiries. Have a nice day ahead!
2023-9-25
DAFlys
Im not convinced it will exceed 250grams,  if that was the case I dont think DJI would have allowed them to fit as you'd being flying a C0 drone with a <249g label on it which would be inaccurate.
2023-9-26
Space Dream
DAFlys Posted at 9-26 01:02
There are weight measurements on YT that clearly show that with a Mini 3 Pro battery in the Mini 4 Pro
this then weighs over 250 grams, which is of course also the case when this stronger battery is used
2023-9-26
DAFlys
Space Dream Posted at 9-26 01:23
But not on proper scales only kitchen scales which are usually not accurate enough to weigh to the degree needed.
2023-9-26
Space Dream
DAFlys Posted at 9-26 01:31
I must disagree, these so-called kitchen scales are very accurate,
it is not about milligrams but only 1 gram resolution ...
2023-9-26
DAFlys
Space Dream Posted at 9-26 01:47
Mine are out by 5 grams compared with my jewellers scales
2023-9-26
Space Dream
If I use the new slightly lighter and slightly more powerful batteries of the Mini 4 Pro
with the Mini 3 Pro, the Mini 3 Pro should actually have a slightly longer flight time ?
2023-9-26
Mobilehomer
From the DJI store Mini 4 Pro accessories page.
2023-9-26
Potato mini
Mobilehomer Posted at 9-26 04:37
[view_image]
thanks for the info
2023-9-26
Space Dream
This is the data from the DJI page for the M4P battery
Strange that no compatibility to M3P is specified ... ?
2023-9-26
Mavic57pro2
Flight distance : 3772247 ft
You are 100% correct. I Just weighed the M4P with the M3P battery inserted, this increased the M4P by 3 grammes.
2023-9-26
SeehawerB
Flight distance : 5414203 ft
Mini 4 Pro with Mini 4 Pro Battery: 03_249,2g_mit_Akku_M4P_anon.jpg
Mini 4 Pro with Mini 3 Pro Battery:
2023-9-26
BrianKushner
Flight distance : 44281716 ft
The new Mini 4 battery also has a higher 2590 to 2453
2023-9-27
Space Dream
I have now once weighed my Mini 3 Pro battery on two different precision balances (one goes to 500g the other to 100g) and the result was almost identical but higher than specified: 81.4g & 81.5g And my Mini 3 Pro also weighs in original condition not 249g but 250g ? Exactly this 1 gram extra weight with my battery brings my Mini 3 Pro probably on the 250g and not as indicated on 249g !
2023-9-27
Potato mini
Space Dream Posted at 9-27 23:09
The plus batterys bring the m3p above the 250 gram limit I think. it brings them up to 252-253grams?
2023-9-28
Space Dream
Potato mini Posted at 9-28 09:40
I do not know as i have no plus battery with longer flight time
Tthe "Plus" battery is significantly heavier at 121 grams !
2023-9-28
Potato mini
Space Dream Posted at 9-28 09:59
How much does the standard batterys weigh?
2023-9-28
Space Dream
Potato mini Posted at 9-28 10:15
DJI wrote 80.5g but my is 81.5g
2023-9-28
Potato mini
Space Dream Posted at 9-28 10:24
wow. the plus batterys are way heaver. how many batterys do you have?
2023-9-28
djiuser_BmAtsRWC4Ej8
Flight distance : 457703 ft
Thanks for the info
2023-9-29
Potato mini
your welcome
2023-9-29
